How Many Beats Will Be Heard in 10 Seconds with Frequencies of 1000Hz and 998Hz?
  • Thread starter Thread starter BarCode
Two audio frequency generators set at 1000Hz and 998Hz produce beats due to their frequency difference. The beat frequency is calculated by subtracting the lower frequency from the higher frequency, resulting in 2Hz. To find the total number of beats heard in 10 seconds, the formula beats = frequency * time is applied. This results in 20 beats being heard over the 10-second duration. The discussion emphasizes the importance of correctly applying the formula for calculating beats.
BarCode
[SOLVED] Calculating Beats
A person has two audio frequency generators with which to demonstrate beats. One generator is set to 1000Hz and the other to 998Hz. How many beats will be heard in 10s?
f = number of beats/time
number of beats = time/f
= 1000Hz/10s
= 100Hz
= 998Hz/10s
=99.8Hz
Then I subtracted the two, getting 0.2 beats, which is most utterly wrong.
Why are you dividing the frequencies by 10 before you subtract? You want to find the differences in the frequencies to figure out the beat frequency. Once you know the beat frequency, you can figure out how many beats there are in 10 seconds.
Ah, so I'd do
1000Hz - 998Hz = 2Hz
beats = 2Hz/10s (rearranged f = b/t to b = f/t)
That's not right, that's the same answer you just had. What's the definition of frequency? Check your units to see if you think they make sense.
Likes gracy
Ah I see where my rearrangement went wrong, it should be
Beats = frequency * time
so...
beats = 2Hz * 10s
= 20 beats
That's right.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
