How many extra electrons does the toner particle carry?
The discussion revolves around calculating the charge on a toner particle and determining how many extra electrons it carries. The charge required for the toner particle to be attracted to the imaging drum is calculated to be 1.44E-15 C, which is 10 times its weight. To find the number of extra electrons, one must divide this charge by the charge of a single electron, approximately 1.6E-19 C. This calculation results in approximately 9.03E+3 extra electrons. The conversation emphasizes understanding the relationship between charge and the number of electrons in the context of electrostatic forces.
jbirse
A photocopier imaging drum is positively charged to attract negatively charged toner particles. Near the surface of the imaging drum, the E field has a magnitude of 1.90 × 105 N/C
A. What must be the be the magnitude of the negative charge on a toner particle of mass 2.80 × 10 -12 kg if it is to be attracted to the drum with a force that is 10.0 times its weight?
B. How many extra electrons does the toner particle carry?
I have already figured out A with F=qe and W=mg
That answer came out to be = 1.44E-15 C
I can't figure out B. How many extra electrons does the toner particle carry?
The answer here is 9.03E+3 but I don't know how that is the right answer, can someone please explain? I feel like it is probably just a formula, but i don't know it
So you know the total charge is -1.44 x 10-15 Coulombs.
The next thing to ask yourself is how much charge (i.e. how many Coulombs) is carried by a single electron? (You can look this up if you haven't memorized it.) :wink:
[Edit: And welcome to Physics Forums, jbirse!]
Thanks! I knew it was probably pretty simple, but I was just unsure of what to exactly do. thanks
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
