MHB How many factors does the number 19 x 29 x 59 x 79 have?
  • Thread starter Thread starter justinepark
    Factors
The number 19 x 29 x 59 x 79, which is the product of four distinct prime numbers, has a total of 16 factors, including 1 and itself. To find the number of factors excluding 1 and the number itself, the calculation shows there are 14 factors remaining. This is derived from the formula for the number of factors, where each prime contributes two choices (either included or not), leading to 2^4 combinations. The discussion emphasizes the multiplicative property of the function that counts factors, confirming that the primes are pairwise coprime. Thus, the final answer is that there are 14 factors when excluding 1 and the product itself.
justinepark
Having trouble with this problem, appreciate help.
Excluding 1 and itself, how many factors does the number 19 x 29 x 59 x 79 have?
Mathematics news on Phys.org
$$n=p_1^{a_1} p_2^{a_2} \dots p_k^{a_k}$$
where $p_i$ are primes ($p_i \neq p_j$) and $a_i >0$.
The number of factors of $n$ is equal to $$\tau(n)=(a_1+1)(a_2+1) \dots (a_k+1)$$
the number $19 *29 *59 * 79$ is product of 4 primes and for each factor there is choice of 2 for each prime so 2^4 ot 16 factors as per How to Find How Many Factors Are in a Number: 4 Steps
to illustrate the factors are
1 $19^0*29^0*59^0*79^0$ or 1
2 $19^1*29^0*59^0*79^0$ or 19
3 $19^0*29^1*59^0*79^0$ or 29
4 $19^1*29^1*59^0*79^0$ or 19 * 29
5 $19^0*29^0*59^1*79^0$ or 59
6 $19^1*29^0*59^1*79^0$ or 19 * 59
7 $19^0*29^1*59^1*79^0$ or 29 * 59
8 $19^1*29^1*59^1*79^0$ or 19 * 29 * 79
and 8 product of the above combinations and 79
if one has to exclude 1and itself then 14 factors
That's right!
Using the formula I wrote in my previous post, we have the following:
$$n=19^1 \cdot 29^1 \cdot 59^1 \cdot 79^1$$
$$\tau{(19 \cdot 29 \cdot 59 \cdot 79)}=2 \cdot 2 \cdot 2 \cdot 2=2^4=16$$
At the $16$ factors, $1$ and itself are included.
Therefore, the number of factors excluding $1$ and itself is equal to $14$.
Well, it's more or less enough to note that $\tau$ is multiplicative instead of using that formula : elts of $\{19, 29, 59, 79\}$ are pairwise coprime. Indeed, they are all primes.
$$\tau(19 \cdot 29 \cdot 59 \cdot 79) = \tau(19) \cdot \tau(29) \cdot \tau(59) \cdot \tau(79) = 2 \cdot 2 \cdot 2 \cdot 2 = 2^4$$
In an "english" translation, if $p$ is a prime then there are only two factors of $p$ : $\{1, p\}$. For $p_1 \cdot p_2 \cdot p_3 \cdot p_4$, $p_i$s being prime, looking for number of factors is essentially equivalent to finding how many ways one can pick a single ball from each box, given 4 boxes with 2 balls inside marked as $1$ and $p$. It's an easy exercise in combinatorics to show that there are indeed $2^4$ ways to do it.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
