How many integers in between \sqrt{19} and \sqrt{90}
  • MHB
  • Thread starter prasadini
  • Tags
    Integers
In summary, the integers between the square roots of 19 and 90 are 5, 6, 7, and 8. To find the number of integers between these two numbers, you can subtract the two square roots and add 1, as the integers include both the starting and ending number. The smallest integer between the two square roots is 5. There are no negative integers between the square roots of 19 and 90, as the square root of a number is always a positive value. Additionally, there are no non-integer values between these two numbers, as the square root of a number can only be an integer or an irrational number.
prasadini
how many integers are between \sqrt{19} and \sqrt{90}
Mathematics news on Phys.org
prasadini said:
how many integers are between $\sqrt{19}$ and $\sqrt{90}$
You can use math tags "" or "$$" to encase your typeset equations.
Have you had a go at the problem?
Do you understand what this question is asking? 19 lies between 16 and 25 so the first integer larger than \(\displaystyle \sqrt{19}\) is what? 90 lies between 81 and 100 so the last integer less than \(\displaystyle \sqrt{90}\) is what?
How many integers lie between \(\displaystyle \sqrt{19}\) and \(\displaystyle \sqrt{90}\)?
FAQ: How many integers in between \sqrt{19} and \sqrt{90}
What is the range of integers between √19 and √90?
The integers between √19 and √90 are 5, 6, 7, 8.
How can I find the number of integers between √19 and √90?
To find the number of integers between √19 and √90, you can subtract the two square roots and add 1. This is because the integers between two numbers include both the starting and ending number.
What is the smallest integer between √19 and √90?
The smallest integer between √19 and √90 is 5.
Is there a negative integer between √19 and √90?
No, there are no negative integers between √19 and √90. The square root of a number is always a positive value.
Are there any non-integer values between √19 and √90?
No, there are no non-integer values between √19 and √90. The square root of a number can only be an integer or an irrational number.
