MHB How many marbles are in a jar?
  • Thread starter Thread starter Max CR
The discussion centers around estimating the number of marbles in a jar, with calculations suggesting there should be 262 marbles based on the jar's volume and the volume of individual marbles. However, the actual count is 167 marbles, indicating a discrepancy. The difference arises from the assumption that the jar is 74% filled, which does not account for the irregular packing of the marbles. The calculations highlight the importance of considering the space between marbles when estimating quantities. The issue has been identified and resolved by the original poster.
Max CR
There are about 167 marbles in a jar.
Volume of sphere (marbles) = (4/3)πr^3
r = (4/3)π(0.25)^3
volume of sphere/marble = 0.0654 inches
Volume of cylinder (glass) = v=πr^2h
v=π(1.625)^2*2.80
volume of cylinder/glass = 23.23 inches
It is a given that the glass is 74% filled and 26% empty due to space in between the marbles.
Number of marbles = (jar volume * 0.74)/volume of one marble
= (23.23*0.74)/0.0654
= 262 marbles
Math says that there is 262 marbles when it is actually 167 marbles. Any ideas?
Mathematics news on Phys.org
I have figured out the problem. Thank you.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
