MHB How many minutes does it take 14 people to paint 14 walls
  • Thread starter Thread starter Devilsleone134
    Paint
It takes 28 minutes for 7 people to paint 7 walls, which implies that 1 person takes 28 minutes to paint 1 wall. Therefore, if there are 14 people painting 14 walls, they can work simultaneously on separate walls. Since each group of 7 people takes 28 minutes to complete their task, both groups will finish in the same time frame. Consequently, it will also take 28 minutes for 14 people to paint 14 walls.
Devilsleone134
I need help with a question that has been bugging me for a while
Here is the question
It takes 28 minutes for 7 people to paint 7 walls.
How many minutes does it take 14 people to paint 14 walls?
Mathematics news on Phys.org
this statement is equivalent to saying it takes 28 minutes for 1 person to paint 1 wall ... so, how long for 14 people to paint 14 walls?
Imagine that as two separate work sites. At one 7 people are painting 7 walls. How long does that take them? At the other another 7 people are painting another 7 walls. How long does that take them? And, of course, the two groups of people started at the same time.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
