How many of these are isomorphisms?
  • Thread starter Thread starter Phred Willard
Phred Willard
Show that the number of group homomorphisms from Zn to Zn is equal to n. How many of these are isomorphisms?
It has been shown by other proofs that the number of homomorphisms from Zm to Zn is the gcd(m,n), but here m=n, so the gcd(n,n)=n so that is the number of homomorphisms. (Correct?) and I have no idea how to determine how many would be isomorphisms.
Since 1 generates Zn, any homomorphism is determined by where 1 gets sent. So the image of a homomorphism is generated by the image of 1. What elements of Zn generate Zn?
Wouldn't it be all elements relatively prime to n? In the case of Z6:1,3,5; In the case of Z8:1,3,5,7
Yep.
Does this necessarily mean that there are only 3 homomorphisms in the case of Z6->Z6?
I was under the impression that the number of homomorphisms in this example would be 6! = 720 and only 6 of those would be isomorphisms.
Here was my thought process:
The mappings cycle through, i.e. Z1 maps to Z1-6, then Z2 maps to Z1-6, on till Z6 maps to Z1-6, giving 6! homomorphisms. Each isomorphism occurs at Zn->Zn, so Z1->Z1, Z2->Z2, ..., Z6->Z6.
Is that not correct?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
