MHB How many radians does the airplane propeller rotate in 190/3 pi seconds?
The discussion centers on calculating the rotation of an airplane propeller in radians over a time period of 190/3 pi seconds. The initial inquiry questions the correctness of the radian usage, noting that 35 degrees appears small for the number of rotations. Responses confirm that the calculations are correct, suggesting that exact values should be provided for clarity. The recommended values include 190/3 pi radians and 7/2280 seconds. The conversation emphasizes the importance of precision in mathematical expressions.
karush
MHB
OK, want to see if I am using the use of rad properly here
the answer seems very small. but 35 degrees isn't much for all the rotations.
Answer not in book so hope these are correct..
thanks ahead.
Mathematics news on Phys.org
thanks ahead.
Looks good to me! (Sun)
-Dan
Your answers are correct, but I would give exact values instead:
a) $$\frac{190}{3}\pi\text{ rad}$$
b) $$\frac{7}{2280}\text{ s}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
