Studying How much chemistry do I need to know as a theoretical physicist?
The discussion centers on the necessity of chemistry knowledge for theoretical physicists and the transition to experimental physics. The amount of chemistry required largely depends on the specific field of physics being pursued, as theoretical physics encompasses a wide range of topics beyond fundamental areas like particle physics and cosmology. Fields such as quantum chemistry and condensed matter physics do necessitate some chemistry understanding. However, it is emphasized that a physicist can have a successful career without formal chemistry courses, as relevant chemistry concepts can be learned on an as-needed basis for specific problems. For experimental physicists, chemistry may play a role in tools and methods rather than being central to their studies. It is suggested that gaining a comfortable level of chemistry knowledge can enhance understanding of physical processes and potentially increase interest in the field.
AW3Rgo0l
How much chemistry do I need to know as a theoretical physicist in order for this knowledge to be sufficient for research in any field of theoretical physics? It is also interesting to know how difficult the transition from theoretical to experimental physics is? Do experimental physics require deeper knowledge of chemistry? Now I'm in school and I'm very worried about how much time I will need to devote to chemistry, since I don't really like it
It depends on what kind of physics you are going to tackle. "Theoretical physics" is vast. Popular physics tries to sell the idea that theoretical physics is only hyper fundamental stuff like particle physics, cosmology and string theory. However you can also make theory for any kind of physical system including quantum chemistry and condensed matter physics, which require much a bit of knowledge of chemistry.
All that said, it is not necessary, you can do a full career in physics without taking a course in chemistry. When you need to know chemistry to understand a process in a galaxy or the conduction of carbon, you can just learn what you need for that particular problem. As physicists know quantum mechanics, many topics that require "chemistry" are done under a physical perspective and not really a chemical one. The same for experimental physicists, sometimes the chemistry is only part of the tools and not necessarily important for what you are studying.
Lastly, I would recommend to find ways to learn more about chemistry in a way that is comfortable to you (for example, if you do not want to learn stoichiometry you do not have to). Even if it is not necessary, knowing a bit of chemistry can be very helpful in understanding a larger range of physical processes and can make you like physics even more :wink:
Likes gwnorth, futureStudent, Math100 and 2 others
TL;DR Summary: What topics to cover to safely say I know arithmetic ? I am learning arithmetic from Indian NCERT textbook. Currently I have finished addition ,substraction of 2 digit numbers and divisions, multiplication of 1 digit numbers. I am moving pretty slowly. Can someone tell me what topics to cover first to build a framework and then go on in detail. I want to learn fast. It has taken me a year now learning arithmetic. I want to speed up. Thanks for the help in advance. (I also...
guys i am currently studying in computer science engineering [1st yr]. i was intrested in physics when i was in high school. due to some circumstances i chose computer science engineering degree. so i want to incoporate computer science engineering with physics and i came across computational physics. i am intrested studying it but i dont know where to start. can you guys reccomend me some yt channels or some free courses or some other way to learn the computational physics.
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
