How much energy is stored in compressed air?
In summary, the conversation discussed the challenges of storing energy from solar power and the potential solutions. These include using water or salt caverns for compressed air storage, but the most abundant and scalable option may be using bags or balloons in the ocean or lakes. The questions raised were about the volume and force needed for storage, as well as potential issues with the temperature of the compressed air. A paper was shared addressing the first question and the concept of using an adiabatic method for higher efficiency was mentioned. Development of this technology is currently underway by an international consortium.
Jesolar
Hi all,
My name is Jesse and I love renewable energy and finding ways of beating coal. Right now Solar Photovoltaic energy competes with coal in sunny areas during the day, but at night, you need to store the energy from solar and it's not worth it due to the cost of storage mechanisms (might as well build a coal plant). For new power construction, solar + storage doesn't compete if you want to have more than just a day of backup energy. Coal delivers reliable energy regardless of clouds. Some clouds last for 10 days straight.
I'm looking for a way to store power cheaply. The cheapest way is to pump water back up a damn. The second cheapest is to pump salt caverns under ground full of compressed air. Neither of these are abundant everywhere. However, the ocean and lakes are much more abundant and scale-able. I want to know how much energy you can store using a tough air-proof "bag."
I'm not interested in efficiency since this is for long term energy storage (think weeks, months and even years before you need to use it rather than hours or days). Storing the heat from compression won't be useful for this long term storage.
Questions
How much volume will the bags or balloons take up per unit of energy stored at any given depth?
How much force will the anchor need to withstand per unit of energy stored?
When the air blows back up the pipe, will it be so cold that something unwanted happens?
Also, it would be helpful if you knew anything particular about this technology and wanted to share it with me such as best price performance bag or best price performance air pump.
Jesolar said:
The third question is yes, but then how much energy is needed to re-heat the gas?
http://energystorage.org/compressed-air-energy-storage-caes
Adiabatic Method
A much higher efficiency of up to 70% can be achieved if the heat of compression is recovered and used to reheat the compressed air during turbine operations because there is no longer any need to burn extra natural gas to warm up the decompressed air. An international consortium headed by the German energy company RWE is currently working on the development of the necessary components and the heat storage. The pilot plant is scheduled to start operations in 2018. Thermal oil and molten salt storage is being investigated in the US.
Related to How much energy is stored in compressed air?
1. What is compressed air and how is it stored?
Compressed air is air that has been pressurized to a higher pressure than atmospheric pressure. It is stored in a container, such as a tank or cylinder, that is designed to withstand the pressure without leaking or rupturing.
2. How is energy stored in compressed air?
When air is compressed, the molecules are pushed closer together, creating potential energy in the form of increased pressure. This energy can be released and converted into mechanical energy when the compressed air is allowed to expand and do work, such as powering a tool or machine.
3. What factors affect the amount of energy stored in compressed air?
The amount of energy stored in compressed air depends on the volume of air being compressed, the pressure at which it is compressed, and the temperature of the air. Higher pressures and lower temperatures can result in more energy being stored in the compressed air.
4. How is the energy stored in compressed air measured?
The energy stored in compressed air is typically measured in units of joules (J) or kilojoules (kJ). It can also be measured in units of pressure, such as pounds per square inch (psi) or bar. The specific measurement used may vary depending on the application.
5. What are some common uses for compressed air?
Compressed air is commonly used as a source of energy in various industrial and commercial applications. It can power pneumatic tools, such as drills and nail guns, as well as larger machinery like air compressors and turbines. It is also used in transportation, such as in air brakes for trucks and buses, and in household appliances like refrigerators and air conditioners.
  • Mechanical Engineering
  • DIY Projects
9K
  • General Engineering
