How Much Fuel Must a Rocket Burn to Double Its Exhaust Speed?
  • Thread starter Thread starter themadhatter1
    Application Vector
themadhatter1
A rocket burning it's onboard fuel while moving through space has a velocity v(t) and mass m(t) at time t. If the exhaust gasses escape with velocity ve relative to the rocket , it can be deduced from Newton's Second Law of Motion that
m\frac{dv}{dt}=\frac{dm}{dt}\vec{v_{e}}<br />
a. show that \vec{v}(t)=\vec{v}(0) - ln\frac{m(0)}{m(t)}\vec{v_{e}}
b. For the rocket to accelerate in a straight line from rest to twice the speed of it's own exhaust gasses, what fraction of initial mass would the rocket have to burn as fuel?
I already solved part a, I just can't get part b.
I know that:
2\vec{v_{e}}=\vec{v}(0) - ln\frac{m(0)}{m(t)}\vec{v_{e}}
However, I don't know where to go from here to find the initial mass the rocket would have to burn to achieve this velocity. Any ideas?
It seems to be staring you in the face. You have an equation with essentially one unknown. Where in your equation is your initial mass, and what indicates the fraction of it expended at time t?
Oh wait.
you know v(0)=0.
So this could be arranged to be
m(t)\frac{1}{e^2}=m(0)
so it uses 1/e2 of it's fuel. Is this what you were thinking?
The problem is not asking you to find m(0), the initial mass, but rather the fraction of the initial mass which the rocket would have to burn in order to reach the velocity specified. In your equation, you can treat v_e, m(0), and v(0) as known quantities (you are correct that v(0)=0). You should be solving in terms of the only unknown quantity, m(t). Then, the fraction of the initial mass which the rocket has burned at time t is 1-\frac{m(t)}{m(0)}, so put your answer in that form, ie. 1-\frac{m(t)}{m(0)}=... and that should be it.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
