How Much Power Does Niagara Falls Generate?
  • Thread starter Thread starter hshphyss
    Homework Power
The discussion focuses on calculating the power generated by the falling water at Niagara Falls, where water flows at a rate of 1.1 million kg/s and falls 46 meters. The key concept is that the change in potential energy (PE) per second, determined by the mass flow rate, gravitational acceleration, and height, equates to the power generated. Participants emphasize that this change in PE translates into electrical energy. The problem-solving approach involves applying the formula for power derived from potential energy. Understanding these principles is crucial for accurately determining the power output of the falls.
hshphyss
Can anyone help me with this problem? Thaak-you
Water flows over a section of Niagara Falls at the rate of 1.1 106 kg/s and falls 46.0 m. How much power is generated by the falling water?
I know that Power is work/time... but this problem is set up differently then I'm used to.
Well (somebody correct me if I'm wrong!) ... when water falls from a high place, its potential energy decreases. For a waterfall, the change in PE per second is equal to the rate times acceleration due to gravity times the height. When converted into electrical energy, the power is equal to the change in PE. See if that works out for ya. :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
