How Much Space Does 0.736 kg of Oxygen Occupy at 1°C and 105 Pa?
To determine the volume occupied by 0.736 kg of molecular oxygen at 1°C and 105 Pa, the ideal gas law equation PV=nRT is used. The number of moles (n) is calculated using the correct molar mass of oxygen, which is 32 g/mol, leading to n = 23. The volume (V) can then be calculated using the rearranged equation V = nRT/P, substituting in the values for R, T, and P. The initial calculation was incorrect due to an error in determining the number of moles. The correct approach clarified that the mass should be converted properly to find the number of moles before calculating the volume.
cstout
A mass of 0.736 kg of molecular oxygen is contained in a cylinder at a pressure of 1.0 × 105 Pa and a temperature of 1°C. What volume does the gas occupy?
PV=nRT
V=nRT/P
n=(.736)(1000)/16 = 46
V = (46)(8.31)(274.15)/(1x10^5)
where n = 46
R = 8.31 J/K/mol
T = 274.15k
P = 1x10^5
but that is not the correct answer, what am i doing wrong??
Molecular oxygen is 0_2, two atoms of oxygen per molecule. That makes the molar mass 32g.
so would i multiply the mass of .736(1000)32 to find the n, or basically i still am unsure of finding the n
Multiply? You divided before and that was correct. One mole of O2 has mass 32g. So how many moles is .736kg?
ahh..thanks, i got it now
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
