How Much Surface Area Can a 200kW Generator Heat in a Steel Pipe?
To determine how much surface area a 200kW generator can heat in a steel pipe, it is essential to consider the flow rate of the oil and the desired temperature increase. The power required will vary significantly based on whether the pipe is empty or filled with oil, as the convective heat transfer coefficient differs greatly. The geometry of the pipe, including its dimensions and material properties, plays a crucial role in the calculations. Without accounting for the cooling effects of flowing oil, estimates of the pipe's length and surface area may lead to inaccurate results. Accurate calculations require detailed specifications and a clear understanding of the thermal dynamics involved.
nurtas
Hi everyone,
I need your help.
Currently working on the task.
Normally have a power generator of 200kW, 380V
I need to heat up the steel pipe by means of resistance, so that I will have inside temperature of the pipe 80C. The function of pipe is to transfer, heat the oil.
As a first step of this question, I have to calculate how much area can this power generator heat up.
If you have any idea, can you help me please,
Regards,
Nurtas
If you are heating oil in the pipe, the power requirement is going to depend heavily on the flow rate through the pipe. Look at the power required to heat the oil to a given \DeltaT at a specific flow rate. You will then need to balance the velocity of the oil in the pipe and the residency time of the oil in the pipe. That will give you the length of pipe you will be using. Then you have to add the power required to heat that amount of pipe to that value to get your overall power requirement (in a perfect world).
ok
Ok, let's think that there is no oil, the only i have to calculate how much area I can heat with so much power.i think this will be the analogue of the electric oven.The problem is now i am not able to calculate the area, i know the pipe/material characteristics, I am just stuck on.
Please describe the geometry (pipe dimensions and materials, location of current leads) and requirements (what length of pipe do you wish to heat) in more detail. The numbers for still air will turn out to be completely different from the numbers for flowing oil (huge difference in convective heat transfer coefficient).
Material is carbon steel, OD:3.5 in, thickness:0.398 in, Specific heat:105 kCal/kg C, thermal conductivity:360,
generator is:200kW
I don't know the length, as you know length and resistance are directly proportional.
If you calculate the length/surface area of the pipe using 200 kW as the input power without taking into account the cooling effects of the flowing oil, you're going to be making your pipe too long and the power available will not be enough to get the pipe to the desired temperature.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
