How much time will elaspe for the microphone picks up a disturbance?
  • Thread starter ohheytai
  • Tags
    Time
In summary, to calculate the effective stiffness of the interatomic bond in iron, we used the formula for Young's modulus and the formula for wave speed. The resulting value was 46.5 N/m. To calculate the time it takes for a disturbance to travel through the iron bar, we used the formula for wave speed and the values for Young's modulus and density of iron. The resulting time was approximately 0.00044 seconds.
ohheytai
85
One mole of iron (6.02x10^23 atoms) has a mass of 56 grams, and its density is 7.87 grams per cubic centimeter. You have a long thin bar of iron, 2.4 m long, with a square cross section, 0.15 cm on a side.
You hang the rod vertically and attach a 234 kg mass to the bottom, and you observe that the bar becomes 1.22 cm longer. Calculate the effective stiffness of the interatomic bond, modeled as a "spring": answer is 46.5N/m
Next you remove the 234 kg mass, place the rod horizontally, and strike one end with a hammer. How much time t will elapse before a microphone at the other end of the bar will detect a disturbance? i can't find this part i don't know how to do it its no where in my book
To calculate the time it takes for a disturbance to travel through the iron bar, we can use the formula for wave speed, v=√(E/ρ), where E is the Young's modulus of iron and ρ is its density.
First, we need to calculate the Young's modulus of iron. This can be done using the formula E = stress/strain, where stress is the force applied and strain is the resulting deformation. In this case, we know that the bar became 1.22 cm longer when a 234 kg mass was attached to the bottom, so the strain is 1.22 cm/2.4 m = 0.0005083. The stress can be calculated using the formula stress = force/area. The area of the cross section of the bar is (0.15 cm)^2 = 0.0225 cm^2. Therefore, the stress is (234 kg)(9.8 m/s^2)/(0.0225 cm^2) = 1.02x10^7 N/cm^2.
Now, we can plug these values into the formula for Young's modulus: E = (1.02x10^7 N/cm^2)/(0.0005083) = 2.01x10^10 N/cm^2.
Next, we can plug this value of E and the density of iron (7.87 g/cm^3) into the formula for wave speed: v= √(2.01x10^10 N/cm^2)/(7.87 g/cm^3) = 5.45x10^3 cm/s.
Finally, we can use the formula for wave speed to calculate the time it takes for a disturbance to travel through the 2.4 m long bar: t = distance/speed = (2.4 m)/(5.45x10^3 cm/s) = 4.40x10^-4 s. Therefore, it would take approximately 0.00044 seconds for a disturbance to travel through the iron bar and reach the microphone at the other end.
Related to How much time will elaspe for the microphone picks up a disturbance?
1. How does the distance between the microphone and disturbance affect the time it takes to be picked up?
The distance between the microphone and the disturbance can affect the time it takes to be picked up. The sound waves travel at a certain speed, so the farther the distance, the longer it will take for the disturbance to reach the microphone. Additionally, the type of disturbance can also impact the time it takes to be picked up.
2. What factors can affect the time it takes for the microphone to pick up a disturbance?
Aside from the distance, other factors that can affect the time it takes for the microphone to pick up a disturbance include the sensitivity of the microphone, the type of disturbance (e.g. loud or soft), and the direction of the disturbance in relation to the microphone.
3. Is there a specific range of time for the microphone to pick up a disturbance?
There is no specific range of time for the microphone to pick up a disturbance as it depends on various factors such as the ones mentioned above. However, in general, it could take anywhere from a few milliseconds to a few seconds for the microphone to pick up a disturbance.
4. Can the material or shape of the disturbance affect the time it takes to be picked up by the microphone?
Yes, the material or shape of the disturbance can affect the time it takes to be picked up by the microphone. For example, a soft material or a curved shape may absorb or deflect some of the sound waves, causing a delay in the time it takes for the disturbance to reach the microphone.
5. How can we measure the time it takes for the microphone to pick up a disturbance?
To measure the time it takes for the microphone to pick up a disturbance, we can use a timer or stopwatch to record the time from when the disturbance is created until it is picked up by the microphone. Additionally, specialized equipment such as oscilloscopes can also be used to accurately measure the time it takes for the disturbance to reach the microphone.
19K
13K
9K
15K
9K
