How Much Work Did Sam Do to Stop the Boat on the Ride?
  • Thread starter Thread starter Rha1828
    Work-energy
Sam is trying to calculate the work done and force applied while stopping a boat at an amusement park. He initially calculated the work as 1.51 J and the force as 11,760 N, but he is uncertain about the accuracy of these figures. A forum member advises against creating duplicate threads and suggests refining questions in a single post for clarity. The discussion emphasizes the importance of following forum guidelines while seeking help with physics problems. Accurate calculations and adherence to community rules are crucial for effective assistance.
Rha1828
Please help! Somple Work-energy problem!
Sam works at an amusement park. A boat of children on a water ride comes the the pier at the end of the ride. They are moving at a constant speed of 1.2 m/s, and the loaded boat has a mass of 1200kg. Sam slows the boat down by pushing on it until it comes to rest at the pier. If he stops it in a distance of 1.75m, and his arms make a 30o angle above the horizontal,
* a) how much work did Sam do on the boat?
* b) how large a force did he apply to the boat?
I thought if I added the mass X gravity that would five me force.
Then I took F cos theta X s to get 1.51 J
and the foce would be 11760.
I am not sure if that is right.
Why would you make two threads within an hour and a half of each other.
Perhaps anyone viewing this should go to
https://www.physicsforums.com/showthread.php?t=300950
I would also advice [for the sake of not being deleted] that you should probably only make one post on each topic and refine from there.
I am not a moderator, just a regular member trying to give you some friendly advice.
Thanks :smile:
Wow you are so helpful thanks! :)
Rha1828, it is against Forum policy to start duplicate threads.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
