How pressure increases in centrifugal compressor?
In centrifugal compressors, pressure increases occur both in the impeller and the diffuser. The impeller, rotating at high speeds, induces air and uses centrifugal force to push it radially outward, which accelerates the air and raises its pressure. The diffuser then converts the kinetic energy of the air into pressure energy through divergent passages. While the diffuser is crucial for pressure conversion, the impeller also contributes significantly to the initial pressure rise. Understanding these dynamics clarifies the overall operation of centrifugal compressors.
Science20
TL;DR Summary
Confusion about operation principle of centrifugal compressor
I have read this in my textbook about principles of operation of centrifugal compressor:
"The impeller is rotated at high speed by the turbine and air is continuously induced into the center of the impeller. Centrifugal action causes it to flow radially outwards along the vanes to the impeller tip, thus accelerating the air and also causing a rise in pressure to occur. The engine intake duct may contain vanes that provide an initial swirl to the air entering the compressor. The air, on leaving the impeller, passes into the diffuser section where the passages form divergent nozzles that convert most of the kinetic energy into pressure energy. In practice, it is usual to design the compressor so that about half of the pressure rise occurs in the impeller and half in the diffuser."
I thought that the pressure increase is only obtained in the diffuser part of the compressor as kinetic energy is converted to pressure, how compressor impeller also contributes to pressure increase?
The answer to your question is in the following figure from Chapter 3: Theory of the Centrifugal Pump Impeller in the book Centrifugal and Axial Flow Pumps by A.J. Stepanoff.
Please don't ask me to interpret it. I read the rest of the book and only skimmed the theory chapter. This figure is from a book about pumps, so is based on incompressible flow. Your question adds the additional factor of compressible flow. I expect that a better discussion would be in the following book by the same author, which I have not read: https://www.amazon.com/dp/B0007E6V9I/?tag=pfamazon01-20. Out of print, but should be in some engineering libraries.
Or an oversimplified answer would be that the impeller spins, and centrifugal force pushes the gas outward hard enough to compress it.
The impeller can also be a diffuser. Looking at the following velocity triangles, when you consider the relative velocities (i.e. ignoring the fact that the impeller rotates, just the flow through it) you can see that ##v_{r2}## can be set smaller than ##v_{r1}##, meaning that while traveling through the impeller, the air pressure rises.
Thank you so much. The concept is now clear to me.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
