russ_watters
Mentor
- 23,702
- 11,145
I'd amplify that to say that there are some military planes that are unflyable without their flight control avionics. As-in; you lose power, you eject, period. Clearly, an airliner can't be like that, though; it has to be flyable un-augmented. I'm sure you know that, I'm just pointing it out as a setup for later discussion:FactChecker said:Military airplanes have flight controls with some abilities that a pilot can not match. They can react faster. They also have some safety features to make sure that the pilot (even some excellent ones) do not crash.
Anderson-Paul said:There are thrust and weight differences, but the diameter is the problem. They were given orders in spite of their opposition...Engineering was well aware of the fact, such an installation would directly effect the weight and balance factor, which would alter the flight characteristics of the airliner. Knowing this should have caused the company to altar their plans. MCAS is nothing more than a fix to get by. I can assure you, I will not be one of the passengers on a 737 Max no matter what they call it. If an airplane is within weight and balance standards, the thumb adjustments on the yoke should be enough. All of this highly advanced technology, tends to create issues that can be deadly. A light touch on the controls of my aircraft is more than enough.
I'm on the same page as DaveE. While I don't think I have seen it explicitly stated, my understanding is the plane is still flyable with the automatic trim/stability augmentation features turned-off. Exactly how much more difficult it is to fly it is, I don't know, and I suppose that could matter if it is very difficult to control un-augmented. But I think it is important to recognize that the direct cause of the crashes was a faulty avionics system design, not faulty aerodynamics/handling.DaveE said:First I 100% agree with your opinions of Boeing management (FAA too, IMO). But my understanding is that the "fix to get by" was to avoid pilot training, and perhaps a new type rating, to deal with stall recovery characteristics that were significantly different from the previous versions...
However, with modified (i.e. limited) SW, a redundant AOA system, and newly required type-specific pilot training, I don't agree that this airplane is unsafe.
So I also would have no qualms about flying in one.
Anderson-Paul said:During my research into the demise of both airliners, I found everything from the opinions of the general public, to memos and reports written by company employees. One such report was written by both company test pilots. Both had experienced problems with the MCAS system, and both reported the problems to the company. The problem is, the information the company received, fell on deaf ears. No attempt had been made to correct the MCAS system Issues.
I was most concerned about the conflict between engineering and management , over whether or not to re-engine a fifty year old design, that had been through four cycles of modification change. The discussion between 737 Max project engineering and project management was this, all appeared to oppose a re-engine attempt, on a fifty year old design. On the other hand, both the board members and top level management, approved
going ahead with a fifty year old design. The opposition were all for a new “Clean Sheet“ design. As a pilot and retired research and development engineer for P&W, I would also have opposed using a fifty year old design.
That part of it -- the businessmen vs engineers vs regulators part -- will certainly be debated in engineering ethics classes for decades. The fact that all of that is intertwined with a clear system design flaw makes it more complicated, but to me they are really separate issues. There are pros and cons to a clean-sheet, and it's not just about money. That 50 year old design has proven reliable and safe, and a clean-sheet will eliminate that track record and inject new risks into the system/process. The more new systems you design, the more opportunities you have for design flaws.
