- #281
.Scott
- 3,485
- 1,599
The specific problem that MCAS was meant to solve was that without it, pilots that were accustom to the handling of the 737 could unintentionally put the MAX into a stall - for example, during steep banks. So what MCAS does is monitor the aerodynamic environment of the plane - not its orientation, not its proximity to the ground - just its interface to the air. If it determines that the pilot might be induced to pull harder than he should (that he would on a 737), it will reposition the horizontal stabilizer to create the familiar 737 environment.cyboman said:I had a question before which is sort of related. I still don't understand it completely: If MCAS is meant to be active in scenarios of high AoA and pitch up conditions. Would it ever be active when the plane has a negative pitch attitude. It was suggested this could occur during a dive when the pilot is pitching up to pull out. But it doesn't seem likely adding nose down trim in that scenario would be beneficial so wouldn't it be improbable MCAS would be active then?
I guess it seems counter intuitive imagining MCAS operating in negative pitch attitude scenarios since it's often described as a stall prevention system.
For MCAS, "useful" doesn't mean less effort for the pilot, it means creating the same amount of effort that the pilot expects.
So, let's say that they plane has already stalled - and the nose has dropped as it will even without pitch input from the pilot. What the pilot needs to do now is to push the nose down even more - to pick up air speed. Then the pilot will need to begin a fairly high-G pull up - enough to avoid excessive airspeed and the ground, but not enough to break the plane or injure the passengers. During these maneuvers, all of which are done with the plane pitched towards Earth, the pilot will be operating the yoke mostly by feel. His eyes will be on other things. So it's important that the plane respond based on this expected feel.
