How should I find the following period ## T ## of this solution?
Math100
Consider the differential equation ## \ddot{x}+x+\frac{3}{2}\beta x\lvert x\rvert=0 ##
for ## \beta\geq 0 ## with the solution ## x(t) ## and initial conditions
## x(0)=A>0, \dot{x}(0)=0 ##. Show that the period ## T ## of this solution
is given by ## T=4\int_{0}^{\pi/2}\frac{d\theta}{\sqrt{1+\beta A\sec^2\theta(1-\sin^3\theta)}} ##.
None.
From the original equation of ## \ddot{x}+x+\frac{3}{2}\beta x\lvert x\rvert=0 ##,
I've got ## \ddot{x}\dot{x}+x\dot{x}+\frac{3}{2}\beta x\lvert x\rvert\dot{x}=0
\implies \frac{d}{dt}(\frac{1}{2}\dot{x}^2+\frac{1}{2}x^2+\frac{\beta}{2}x^2\lvert x\rvert)=0
\implies \frac{1}{2}\dot{x}^2+\frac{1}{2}x^2+\frac{\beta}{2}x^2\lvert x\rvert=C ## where
## C ## is the constant.
From the work shown above, how should I use the initial conditions of ## x(0)=A>0 ##
and ## \dot{x}(0)=0 ## to find the given period ## T ##? And where does the factor of
## 4 ## come from in front of the integral sign of the period ## T ##?
Set y = \dot x and switch to scaled polar coordinates (x,y) = (Ar \cos \theta, Ar \sin \theta). The period is then given by <br /> T = \int_0^{2\pi} \frac{1}{\dot \theta}\,d\theta. In this case, by symmetry the integral over the full period from 0 to 2\pi is four times the integral over the quarter period from 0 to \pi/2.
But what's ## \dot\theta ## from the integral?
My earlier hint was unhelpful; please disregard it.
Your first integral gives you an expression for |\dot x| in terms of x, <br /> |\dot x| = F(x) where F is even.
You can therefore start from <br /> T = \int_0^T\,dt = \int_A^0 -F(x)^{-1} \,dx + \int_0^{-A} -F(x)^{-1}\,dx + \int_{-A}^0 F(x)^{-1}\,dx + \int_0^A F(x)^{-1}\,dx.
You can find ## \dot \theta ## by using the substitution ## x=A\sin\theta ##, ## \dot x=A\cos\theta\dot \theta ##.
You do not need to discard the whole post #2. Use the next part
to find the expression for ## T ##.
Thank you!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
