How to add Ammeter in LT Spice Schematic?
  • Thread starter Thread starter Tarek EEIT
    Ammeter Schematic
LT Spice does not have a dedicated ammeter component, but current can be measured using a very small resistor, such as 1 milliohm, placed in the circuit. By hovering over this resistor, users can view the current at that point in DC operating point mode. In Transient mode, clicking on a component will display the current waveform. Alternatively, a zero-volt DC voltage source can be used to simulate an ammeter, with a label indicating its function. This method effectively allows users to measure current in their LT Spice schematics.
Tarek EEIT
It may sound so silly question but I am trying for last 2 hours and no result.
I have drawn the following schematic in LT Spice and want to add an ammeter in the black rectangle. In component menu, I don't find anything named ammeter.
Any clue? Your help is appreciated.
There isn't an ammeter in LT Spice. However, you can certainly measure current.
You can do this by adding a VERY small resistor like 1 milliohm and then moving your mouse onto it. This will give the current at that point.
You can also just do this with any of the existing resistors. Just move your mouse onto them and read off the current in the box at the bottom of the screen.
This would be used when you have the simulation in DC operating point mode.
In Transient mode, you just click on a component and get the current waveform through it.
Another way is to use a DC voltage source of zero volts in the position you require. This will look like an ammeter and behave like one. Just put a label next to it to infer that it is an ammeter.
Awesome reply. Thanks for your comment. I didn't thought in this way. I just tried your process and it works!
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
