How to calculate compression of a spring
To calculate the compression of a spring subjected to centrifugal force while spinning, one must consider the spring's weight and the varying centrifugal force based on radius and RPM. If the radius change is negligible, the spring can be modeled with a small mass at its end, allowing the use of Hooke's Law to determine compression. Alternatively, if the spring's mass is uniformly distributed, the moment of inertia can be calculated using the formula for a rod, with adjustments for angular momentum. The effective point for mass distribution along the spring is approximately 0.577 of the radius. Understanding these principles enables accurate calculations of spring compression under rotational forces.
Gazi
centrifugal force apply force to spring while it spinning, how to calculate it's compression. there is no any attached mass on spring. just centrifugal force depends on RPM. weight of spring is important, centrifugal force is changing by radius, so it's not uniform.
If the change in radius is small compared to the overall radius, then I'd assume a constant r and model the spring as having a small mass attached to the end of it. Then you can find the force on that mass and use hooke's law to find how far the spring is compressed.
Alternatively, if you considered the mass of the spring was uniformly distributed from the origin to the radius, then you could use the moment of inertia of a rod about its end i.e ##I=\frac{1}{3}mr^2## with associated angular momentum ##L=I\omega##. In doing this you're basically attaching all the mass contributing to angular momentum to a point along the spring which is ##1/\sqrt{3}=0.577## along the spring, i.e. between a half and 2/3 of ##r##. There is then an associated centripetal force from which you can get the extension as Drakkith suggested.
inertia moment of long uniform rod through end is I=1/3ML² what if rod has hollow. what is inertia moment?
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
