How to Calculate Displacement and Speed for a Motorboat Journey in Excel?
  • Thread starter Thread starter swingkids
    Excel Lab Vector
To calculate the displacement and speed for a motorboat journey in Excel, the first leg involves traveling 20 minutes at 20 miles/hour, resulting in a displacement of approximately 6.67 miles at 15 degrees East of North. The second leg, lasting 35 minutes at 25 miles/hour, yields a displacement of about 14.58 miles at 20 degrees South of West. The x and y components of both displacements are calculated, leading to a total displacement of approximately 21.23 miles with a direction of 18.4 degrees. The total distance traveled is the sum of the two legs, while average velocity and average speed can be derived from the total displacement and total time. Further calculations for average velocity and speed are needed to complete the analysis.
swingkids
I have to do this problem using Microsoft Excel.
A motorboat leaves the dock and travels in a direction 15 degrees East of North for 20 minutes at a constant speed of 20 miles/hour. At that point the boat abruptly changes its direction to 20 degrees South of West and its speed to 25 miles/hour and continues on that new course for 35 minutes. Assuming that the lake is still, calculate the answers to the following questions:
(a) What is the boat's displacement (magnitude and direction) after 55 minutes?
(b) What is the total distance traveled by the boat?
(c) What is the boat's average velocity (magnitude and direction) after 55 minutes?
(d) What is the boat's average speed after 55 minutes?
First leg: (15 degrees East of North)
Time ? minutes
Speed ? miles/hr
Magnitude of displacement #1 ? miles
Second leg: (20 degrees South of West)
Time ? minutes
Speed ? miles/hr
Magnitude of displacement #2 ? miles
Choose the +x coordinate as East and the +y coordinate as North.
Find the x and y components of the two displacement vectors.
x-comp. y-comp.
displacement #1 ? ?
displacement #2 ? ?
total displacement ? ?
magnitude direction
total distance travelled ?
average velocity ? ?
average speed ?
Obviously each area with a ? needs data or an equation filled in there. If some people can guide me through this, it'd be greatly appreciated.
I guess what I don't understand in the first part is, they want the magnitude of displacement 1. That'd just be d=tv, but t is in minutes, and v is in miles/hr, and you're supposed to keep the answer in miles/hr. When I enter the formula into the "Magnitude of displacement #1 ? miles" part, should I just enter =(11/12)*B16? 11/12 would be the 55 minutes as a fraction of 1 hour, and the B16 is just the cell where the 20 miles/hr is.
*Edit: neglect this. I was using the 11/12 incorrectly, I meant 1/3 in the first part*
Here's what I got so far
Time 20 minutes
Speed 20 miles/hr
Magnitude of displacement #1 6.6666667 miles
Time 35 minutes
Speed 25 miles/hr
Magnitude of displacement #2 14.58333333 miles
x-comp, y-comp
displacement #1: 6.44, 1.73
displacement #2: 13.70, 4.99
total displacement: 20.14, 6.71
magnitude
total displacement: 21.23
"total displacement: 21.23"
Then to get the direction, I took the inverse tangent of (6.71/20.14) and got 18.4 degrees.
Can anyone verify what I have so far?
Now how should I go about the total distance, average velocity, and average speed?
bump, come on
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
