I How to Calculate electron temperature of Arc Plasma?
  • I
  • Thread starter Thread starter akansh_karthik_1
    Plasma physics
Calculating the electron temperature (Te) of arc plasma is essential for determining Spitzer resistivity in arc discharge plasmas. The discussion highlights the need for a mathematical formula or method to derive Te, as many sources focus on measurement techniques rather than calculations. Variations in electron temperature are influenced by current and voltage in the plasma. A Google search revealed useful resources, including a Wikipedia article on Plasma Arc Welding, but the challenge remains in finding a purely mathematical approach. Understanding Te is crucial for accurate plasma modeling and applications in welding and other technologies.
akansh_karthik_1
TL;DR Summary
How to calculate the electron temperature (Te) of an arc plasma with moving through air with current I, and voltage V
I am trying to calculate the spitzer resistivity of an arc discharge plasma and I have not been able to figure out how to calculate electron temperature (Te). What is the formula / method of getting this value? How does electron temperature vary in relation to current and voltage moving through the plasma.
What sources have you been looking through? I did a Google search on electron temperature of plasma arc and got lots of good hits. One of the first ones was a Wikipedia article on Plasma Arc Welding.
Most of the sources that I have found talk about measuring electron temperature through instruments not through some sort of mathematical approach or law.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
