How to Calculate Momentum Space Probability for a Particle Initially in a Box?
The discussion focuses on calculating the momentum space probability for a particle initially in a box of length 2a after the box's walls are removed. The participant plans to use the wave function for a particle in a box and apply the Fourier transform to find the momentum probability density. They express uncertainty about computing the integral involved in the transformation and whether the bounds should be set from p to (p+dp). Suggestions include simplifying the sine term and using exponential forms to facilitate integration. The conversation emphasizes the challenge of resolving the integral, which is believed to yield a combination of delta functions.
Don'tKnowMuch
A particle is initially in the nth eigenstate of a box of length 2a. Suddenly the walls of the box are completely removed. Calculate the probability to find that the particle has momentum between p and p + dp. Is energy conserved?
solution for particle in a box of length L ---->
ψ(x)(sub n) = (2/L)^1/2*sin(n∏x/L)
Fourier Transform of momentum space ----->
ζ(p) = [ 1/(2∏h-bar)^(1/2) ]*∫ e^(-ipx/h-bar)*ψ(x)
I need the probability that the particle is between p & (p+dp). So my plan was to put the ψ(x)(sub n) into the Fourier transform, and then square that to get the probability. My trouble lies in the integral. I am not sure how to compute it. Would the bounds of the integral be p to (p+dp)?
you don't have to do the integral because the P[p+dp,p] = ζ^2(p)dp since ζ^2(p) is the probability density function
This is my understanding, there is a wave function in position space defined for a box of length 2a. This state of definite position is being projected onto a state which has deinfite momentum
ζ(p)^2 = 1/(2∏h-bar) *∫ e^(-ipx/h-bar)^2*( 1/(2a)*sin^2(n∏x/2a))dx
There's still an integral hanging around though. I feel like it needs to be integrated. If that were the case, would i change the sin(stuff) to an exponential and see what comes out?
Hi, in my opinion the computations you have proposed are right. It may be easier to write the exponential as cos+i sin and then use the formulae (from wikipedia :) to compute integrals like sin( ax) cos( bx) or sin( ax) sin( bx) .
Francesco
Looking at the sine term i can simplify the argument a little by setting...
k' = (n∏/2a)
making the sine term------> sin(k'x)
Looking at the exponential, i can say that...
p/h-bar = k
Putting these in the integral looks something like...
ζ(p) = 1/(2∏h-bar)^(1/2)*∫ e^(-ikx)*(1/2i)(e^ik'x-e^-ik'x) dx...
which simplifies to...
ζ(p) = (1/2i)*1/(2∏h-bar)^(1/2)*∫ e^(-ix(k' - k))-(e^-ix(k' + k)) dx...
I have been using every resource at my disposal to crack this one, and to no avail. I saw that the solution to this integral is a combination of delta functions, but i just can't put it together.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
