How to Calculate Optimal Thickness for Thin-Film Optical Coatings
  • Thread starter Thread starter pphy427
    Optical
To achieve the desired optical effects in dichroic glass, the thickness of the MgF2 coating must be calculated to maximize blue reflection at 519 nm while minimizing red transmission at 692 nm. The relevant equations for constructive and destructive interference are provided, with constructive thickness calculated as λm / 2n and destructive thickness as λ(m - 0.5) / 2n. Users discussed strategies for finding suitable m values that satisfy both conditions, emphasizing the need for guess-and-check methods. A phase change due to the refractive index must also be considered, particularly for the blue maximum. Ultimately, solving for the optimal thickness involves balancing these equations to achieve the desired color effects.
pphy427
A jewelry maker has asked your glass studio to produce a sheet of dichroic glass that will appear red (wavelength=692 nm) for transmitted light and blue (wavelength=519 nm) for reflected light. If you use a MgF2 coating (n=1.39), how thick should the coating be.
for constructive interference: lambda = (2nd)/m
for destructive interference: lambda = (2nd)/(m-.5)
Both constructive and destructive interference of the reflected waves are required here, at different wavelengths. I think we need to minimize the red for reflection and maximize the blue. I really don't know how to make sense of this problem. I'm sorry I don't have a better attempt. I will really appreciate any help you can offer. Thanks so much!
I'm having the same issue with this same problem. Just to rephrase the formulas,
Constructive Thickness = \lambdam / 2*n
Destructive Thickness = \lambda(m-.5) / 2*n
I figured the same; that we wanted to maximize blue reflection and minimize red. So far, I've tried solving for the value that makes the red destructive, and tried a few multiples of it (in other words, a few m values) in comparison to the blue construcive in hope I'd find an integer match (ie a 5/4 or something ratio so I can figure the m's), but no luck on that. I've only got one crack at it left, so I want to make sure I get it.
ok, I've been working at this one and i think it's way easier than i thought it was.
we know that the film is the same in both conditions so if we solve both the constructive and destructive formulas for "d" we can find a corresponding "m" value. whether you use the situation where blue is constructive and red is destructive or vice versa, you'll eventually get the same answer.
I see what you mean. Got it to work; I used m=2. Just takes a little guess-and-check.
Thanks
However, you have to take into account the phase change due to n=1.54. So in this case, the equation for blue max is t= \lambda(m+.5) / 2*n
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
