How to Calculate the Concentration Ratio of Myoglobin in a Test Tube?
Myoglobin has a molar mass of approximately 17,000 g/mole, and buoyant correction reduces this to an effective mass of about 0.25m. The discussion involves calculating the concentration ratio of myoglobin at the top versus the bottom of a 4 cm test tube, with the conclusion that myoglobin sinks due to its density being greater than that of water. The initial calculation suggests a concentration ratio of 0 at the top and M at the bottom, resulting in a ratio of 0, which raises concerns about its reasonableness. The problem's mention of molar mass indicates its relevance in understanding the behavior of myoglobin in solution.
mimocs
Myoglobin is a globular protein, with molar mass m ≈ 17,000g/mole. The buoyant correction typically reduces m to m' ≈ 0.25m. Calculate the concentration ratio of the protein at the top of a 4 cm test tube and that at the bottom.
Here, m' stands for effective mass.
I tried as below.
I used the equation of buyoancy so that the effective mass reduce into 0.25m.
m'g = (ρ-ρ')Vg = 0.25mg = 0.25ρVg
(ρ is the density of myoglobin, and ρ' is the density of water)
→ 0.75ρ = ρ'
So since ρ > ρ', I think the myoglobin should sink to the bottom of the test tube.
As a result, the concentration of myoglobin at the top is 0 and let the concentration of the bottom is M.
Then, concentration ratio of bottom and the top becomes 0 / M which gives me 0.
However, I don't think my answer is reasonable.
Why does the problem give me the molar mass?
I hope anyone could ever help me.
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
sorry, I still couldn't find out anything more, wish I knew anything new.
deeply sorry.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
