I How to calculate the focal length and focal point of collimator?
To calculate the focal length and focal point of a collimator with a 3mm diameter, it's essential to consider the active area of the detector, which is 180 micrometers. A sketch of the setup can help clarify the relationship between the collimator and the detector. The current dimensions may not provide sufficient information for accurate calculations. Additional details or parameters may be necessary to proceed effectively. Understanding the geometry and configuration is crucial for precise calculations.
Barbossa
TL;DR Summary
I wanted to calculate the focal length and focal point of the collimator. The collimator diameter is 3mm and I wanted to focus on the 100-micrometre active area of the detector.
I wanted to calculate the focal length and focal point of the collimator. The collimator diameter is 3mm, and I wanted to focus on the 100-micrometre active area of the detector.
Hello @Barbossa ,
:welcome: !​
That is very interesting. Do you have any input for your calculation ?
Is this homework or a school lab ?
Hi
Thanks!. Yeah! The detector active area is 180 µm and lens diameter is 3 mm.
Yes, you said that. Do you realize that isn't enough ? What about a sketch of the situation, and what it is that you want to do -- exactly.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
