How to calculate the ratio of weight?
  • Thread starter Thread starter asteorit
    Ratio Weight
To calculate the ratio of weights for two bodies connected by linear actuators, the forces acting on each body must be analyzed using Newton's second law (F=ma). The bodies move apart under the influence of a force F, with friction considered, and their movements are defined by their respective equations of motion. The key is to establish the relationship between the masses (m1 and m2) based on the total distance L they travel, which is the sum of their individual distances. The discussion emphasizes the need to derive the mass ratio from the equations of motion while considering the forces acting on each body. Understanding this relationship is crucial for determining the mass ratio when the total distance traveled is fixed.
asteorit
Two body move apart by force. Frictional forces are considering. How to calculate the ratio of weight?
m1<m2
Ft1=k*g*m1
Ft2=k*g*m2
v1(t1)=\frac{F_{t1}-F}{m_{1}}*t_{1}
x1(t1)=\frac{F_{t1}-F}{m_{1}}*\frac{t^{2}_{1}}{2}
v2(t1)=\frac{F-F_{t2}}{m_{2}}*t_{1}
x2(t1)=\frac{F-F_{t2}}{m_{2}}*\frac{t^{2}_{1}}{2}
What is the procedure of calculation.
Thank you for your help.
welcome to pf!
hi asteorit! welcome to pf! :smile:
sorry, but i don't understand the set-up :redface:
what is the connection between these two bodies?
Hi tiny-tim,
These two bodies are connected by linear actuators. Force F of the linear actuator, will act on both the bodies. We know that the bodies should move along the path L, L=x1(t1)+x2(t1). We know that m1<m2.
If I assume correctly, and the trajectory of bodies depends on the mass ratio. Or is also dependent on the time t1?
What is the ratio of the mass of bodies\frac{m_{2}}{m_{1}}=?, if the sum of their orbits must be equal to L?
hi asteorit! :wink:
i see … so it's equal-and-opposite-reaction-forces, but without contact
ok, then start by writing out Ftotal = ma for each body …
what do you get? :smile:
tiny-tim said:
hi asteorit! :wink:
I do not understand it, to me you ask? Some will not understand it?
Because I need to know what is the ratio of the masses.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
