How to calculate velocity with target 12 m away vertically and 6 m horizontally?
  • Thread starter Thread starter pill
    Velocity
To calculate the velocity needed to hit a target 12 m away horizontally and 6 m vertically, the angle of launch is specified as 50°. The equations provided include t = 12/Vx, Vy = 6/t + (0.5)(9.81)t, Vx = Vcos(50), and Vy = Vsin(50). The user initially calculated Vx and Vy but found discrepancies in the velocities derived from both equations, indicating a potential error in calculations. To resolve this, it's suggested to eliminate time (t) and express V in terms of known variables. A unique solution requires correctly substituting and solving the equations while maintaining the specified angle.
pill
I used an online simulation for this lab. The target is 12 m away horizontally and 6 m vertically. I was to find the velocity needed to hit the target.Since it's an online simulation, I played around with it and got 14.3 m/s. The formula I plan on using is:
Vx=range/time
Vy=√(range*10-(range/time)²)
V=√(Vx)+Vy
My problem is, how do I calculate the range and time when the target is hit? Or do I use the final range and time in the equation?
The range and time of the first black X is: 9.19 m and 1 s.
The final range and time is 21.6 m and 2.4 s.
I was given these equations and was told to solve for V:
t = 12/Vx
Vx = Vcos(50)
Vy = Vsin(50)
And this is what I got:
t = 12/Vx
2.6=12/Vx
Vx=28.8
Vy=6/2.6+(0.5)(9.81)(2.6)
Vy=14.272
Vx = Vcos(50)
28.8/cos(50)=V
V=29.8456
Vy = Vsin(50)
14.272/sin(50)=V
V= -54.395
The velocity from Vy = 6/t + (0.5)(9.81)t is the same from the simulation, but I think I might have messed up in general. I know V from both equations should be the same, but they're obviously not. Any explanation on what I did wrong and how to fix it?
What angle with the horizontal is specified? I see the number 50 in your work but don't see where it came from. Without an angle specified, the problem does not have a unique solution.
The angle of the cannon is 50°.
Take your equations
t = 12/Vx
Vx = Vcos(50)
Vy = Vsin(50)
and rewrite them with V as one of the unknowns. The other unknown is t. Eliminate t and solve for V. Eliminate the Vx and Vy variables because you know them in terms of V which is what you seek.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
