How to construct a periodic function ## f ## with period ## 4 ##?
The discussion focuses on constructing a periodic function f with a period of 4, specifically requiring f(11) = 1 and f(22) = 2. The initial definition of f is provided, where f is defined at integer multiples of 4 and their remainders. The relationship between the function's values and their corresponding modular results is emphasized, with suggestions to use trigonometric functions to achieve the desired outputs. A proposed solution involves defining the function in terms of sine and cosine, ensuring it maintains periodicity while meeting the specified conditions. The conversation concludes with a suggestion to explore alternative methods for defining the amplitude function A(x) to satisfy the periodicity requirement.
Math100
Construct a periodic function ## f ## with period ## 4 ## for which ## f(11)=1 ## and ## f(22)=2 ##.
None.
On the book, it says, "Let ## f ## be defined by ## f(4n)=f(4n+1)=0, f(4n+2)=2 ## and ## f(4n+3)=1 ##, for all integers ## n ##". (Other answers are possible). But I don't understand, how does this work in the problem? I know that it must has something to do with the period, which is ## 4 ## in here and also has something to do with the modulo, because ## 11\pmod 4=3, 22\pmod 4=2 ##. What to do with these though?
Math100 said:
Homework Statement: Construct a periodic function ## f ## with period ## 4 ## for which ## f(11)=1 ## and ## f(22)=2 ##.
Relevant Equations: None.
What is the domain of the function?
The example indicates that it is the integers. If so, then ##f(11)=f(4\cdot 2 +3)=1 ## with ##n=2## in the definition and ##f(22)=f(4\cdot 5+2)= 2## with ##n=5## in the definition, so the two requested values are obtained by the given definition of ##f##.
Now you could prove that ##f(m)=f(m+4)## for all non-negative integers by induction, starting with ##m=0## and then that it also holds for negative values of ##m.## But ##f(-m)\neq f(m)## so you must be careful.
However, as you correctly observed, you need to consider four different cases with ##m \equiv a \in\{0,1,2,3\} \pmod{4}## anyway, so forget the induction and the negative values. Instead, let's observe (prove) that ##f(m)=f(a)## for any integer ##m## with ##m\equiv a\pmod{4},## and note that ##f(a)## is per definition of period ##4.##
For an example with real values, I would consider ##y=A\cdot \sin\left(\dfrac{2\pi}{4}\cdot x\right)+B\cdot \cos\left(\dfrac{2\pi}{4}\cdot x\right)## which makes it of the period ##4## and determine the values of ##A## and ##B## by ##y(11)=1## and ##y(22)=2.## You have two fixed points so I suggested two trig functions with two independent parameters ##A,B.## If you are lucky, then one might do, but I don't think so. Another possibility is to use ##y=A(x)\cdot \sin\left(\dfrac{2\pi}{4}\cdot x\right)## and define a function ##A(x)## instead of two parameters accordingly.
Likes docnet and Math100
For ## y=A\cdot sin(\frac{2\pi}{4}x)+B\cdot cos(\frac{2\pi}{4}x) ##, I've got ## y(11)=1\implies 1=A\cdot sin(\frac{11\pi}{2})+B\cdot cos(\frac{11\pi}{2})\implies 1=-A+0\implies A=-1 ## and ## y(22)=2\implies 2=A\cdot sin(11\pi)+B\cdot cos(11\pi)\implies 2=0-B\implies B=-2 ##. With ## y=A(x)\cdot sin(\frac{2\pi}{4}x) ##, we have ## y(11)=1\implies 1=A(11)\cdot sin(\frac{11\pi}{2})\implies 1=A(11)\cdot (-1)\implies A(11)=-1 ## and ## y(22)=2\implies 2=A(22)\cdot sin(\frac{11\pi}{2})\implies 2=A(22)\cdot (-1)\implies A(22)=-2 ##. Since ## 11\pmod {4}=3, 22\pmod {4}=2 ##, it follows that ## f(11)=f(3)=1, f(22)=f(2)=2 ##. To define a periodic function for ## x=0, 1, 2, 3 ## where period is ## 4 ##, I've got
\begin{align*}
f(x) = \begin{cases}
a & \text{if } x \equiv 0\pmod {4}\\
b & \text{if } x \equiv 1\pmod {4}\\
2 & \text{if } x \equiv 2\pmod {4}\\
1 & \text{if } x \equiv 3\pmod {4}.
\end{cases}
\end{align*} for some ## a, b\in\mathbb{Z} ##.
Correct. That makes it ##y(x)=-\sin\left(\dfrac{\pi x}{2}\right) -2\cos\left(\dfrac{\pi x}{2}\right).##
This is wrong. We have
\begin{align*}
y(11)&=A(11)\sin \left(\dfrac{11\pi}{2}\right)=A(11)\cdot (-1)=1 \\
y(22)&=A(22)\sin \left(\dfrac{22\pi}{2}\right)=A(22)\cdot 0 = 0\neq 2
\end{align*}
which means my idea does not work. We have to avoid that the sine value hits a point where it is zero. The easiest way to correct this is to shift the wave. This doesn't change the period but shifts the points so that the sine isn't zero.
Set ##y(x)=A(x)\cdot \sin \left(\dfrac{\pi x}{2}+\dfrac{\pi}{4}\right).## Now,
a) prove that ##y(x)=y(x+4n)## for all ##n\in \mathbb{Z},##
b) prove that ##y(11)\neq 0## and ##y(22)\neq 0## and
c) find an amplitude function ##A(x)## such that ##y(x)=A(x)\cdot \sin \left(\dfrac{\pi x}{2}+\dfrac{\pi}{4}\right)## with ##y(11)=1## and ##y(22)=2.##
Note: You could define a straight ##A(x)## such that ##y(11)=1## and ##y(22)=2.## However, such a linear increasing or linear decreasing amplitude would destroy the periodicity of ##y(x).## We need therefore an amplitude function ##A(x)## which itself is of period ##4.## Any idea what we could choose for such a ##A(x)##?
d) I would also recommend to do the same thing with ##z(x)=B(x)\cdot \sin \left(\dfrac{\pi x}{2}+\dfrac{\pi}{3}\right),## just for practice.
\begin{align*}
\end{cases}
Ok, but you need the same property as in your given example, namely that ##f(m)=f(c)## for any integer ##m\equiv c \pmod{4}## or in the long version, that ##f(4n)=f(0)=a\, , \,f(4n+1)=f(1)=b\, , \,f(4n+2)=f(2)=1\, , \,f(4n+3)=f(3)=1.## The function ##f## must be defined to have this property.
Please consider elaborating a) - d) since it is a good practice. And don’t be so stingy with text paragraphs.
\begin{align*}
\end{align*}
a) Let ## y(x)=A(x)\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{4}) ##.
Then ## y(x+4n)=A(x+4n)\cdot sin(\frac{\pi(x+4n)}{2}+\frac{\pi}{4})=A(x+4n)\cdot sin(\frac{\pi\cdot x}{2}+2\pi\cdot n+\frac{\pi}{4}) ##.
Note that ## sin(x)=sin(x+2\pi\cdot n) ## by the trigonometric identity, so we have ## sin(\frac{\pi\cdot x}{2}+2\pi\cdot n+\frac{\pi}{4})=sin(\frac{\pi\cdot x}{2}+\frac{\pi}{4}) ##.
This gives ## y(x+4n)=A(x+4n)\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{4}) ##.
Thus, ## y(x)=y(x+4n)\implies A(x)\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{4})=A(x+4n)\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{4}) ##.
Therefore, ## y(x)=y(x+4n) ## for all integers ## n ##.
b) Given that ## y(x)=A(x)\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{4}) ##, we have ## y(11)=A(11)\cdot sin(\frac{11\pi}{2}+\frac{\pi}{4})=A(11)\cdot (-\frac{\sqrt{2}}{2}) ## and ## y(22)=A(22)\cdot sin(11\pi+\frac{\pi}{4})=A(22)\cdot (-\frac{\sqrt{2}}{2}) ## but how to prove that ## y(11)\neq 0 ## and ## y(22)\neq 0 ## from here? It must be the case that ## A(11) ## and ## A(22) ## are nonzero in order for ## y(11)\neq 0 ## and ## y(22)\neq 0 ##, but then how to prove that ## A(11) ## and ## A(22) ## are nonzero?
c) Consider ## y(x)=A(x)\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{4}) ## such that ## y(11)=1 ## and ## y(22)=2 ##.
Then ## y(11)=1\implies 1=A(11)\cdot sin(\frac{11\pi}{2}+\frac{\pi}{4})\implies 1=A(11)\cdot (-\frac{\sqrt{2}}{2})\implies A(11)=-\sqrt{2} ## and ## y(22)=2\implies 2=A(22)\cdot sin(11\pi+\frac{\pi}{4})\implies 2=A(22)\cdot (-\frac{\sqrt{2}}{2})\implies A(22)=-2\sqrt{2} ##.
As of finding the amplitude function from here, would it just be ## A(x)=-\sqrt{2} ##?
FWIW, since the question has essentially been answered, here’s an alternative solution.
A = (11,1), B = (22,2). The period is 4 so there are ##\frac {22-11}4 =## eleven quarter-cycles between A and B. The angular frequency (considering trig' functions) is ##\frac {2 \pi }4 = \frac {\pi}2##.
We note that ##f(x)## increases by 1 from A to B, that there are an odd number of quarter-cycles between A and B and that sine changes by ##\pm## 1 each quarter-cycle.
##\sin(\frac {11 \pi}2) = -1##
##\sin(\frac {22 \pi}2) = 0##
So ##f(x) = \sin(\frac {\pi x}2) +2## is a solution.
Correct.
We are free to choose a function ##A## appropriately since this is a parameter we can freely choose. We only have to make sure that it is of period four. Constant functions are the easiest ones.
If ##A(x)=-\sqrt{2}## then ##A(22)=-\sqrt{2}\neq -2\sqrt{2}.##
If ##A(x)=-\sqrt{2}\cdot x## then ##A(x)## hasn't the period ##4## since it is linearly decreasing.
However, we already know a function ##y(x)## of period ##4## such that ##y(11)=1\, , \,y(22)=2.## We can therefore define ##A(x)=-y(x)\cdot\sqrt{2}.## That function was ##y(x)=-\sin\left(\dfrac{\pi x}{2}\right) -2\cos\left(\dfrac{\pi x}{2}\right).##
So
y(x)=\left(\sqrt{2}\sin\left(\dfrac{\pi x}{2}\right) + 2\sqrt{2}\cos\left(\dfrac{\pi x}{2}\right)\right) \cdot \sin\left(\dfrac{\pi x}{2}+\dfrac{\pi}{4}\right)
is another solution but @Steve4Physics' solution is easier and straight forward. I guess we both tend to make things more complicated than necessary.
The main message of this exercise is, that modulo functions are suited to get periodic functions on the integers, and that sine and cosine functions are suited to get periodic functions on the real numbers. The most general functions are ##y(x)=A(x)\sin (\omega x + a)+B(x)\cos(\omega x +b) +c,## but sometimes ##y(x)=\sin (\omega x )+c## already does the job.
fresh_42 said:
Correct.
So
d) Let ## z(x)=B(x)\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{3}) ##.
Then ## z(x+3n)=B(x+3n)\cdot sin(\frac{\pi(x+3n)}{2}+\frac{\pi}{3})=B(x+3n)\cdot sin(\frac{\pi\cdot x}{2}+\frac{3\pi\cdot n}{2}+\frac{\pi}{3}) ##.
Note that ## sin(x)=sin(x+2\pi\cdot n) ## by the trigonometric identity, so we have ## sin(\frac{\pi\cdot x}{2}+\frac{3\pi\cdot n}{2}+\frac{\pi}{3})=sin(\frac{\pi\cdot x}{2}+\frac{\pi}{3}) ##.
This gives ## z(x+3n)=B(x+3n)\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{3}) ##.
Thus, ## z(x)=z(x+3n)\implies B(x)\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{3})=B(x+3n)\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{3}) ##.
Therefore, ## z(x)=z(x+3n) ## for all integers ## n ##.
Consider the conditions ## z(11)=1 ## and ## z(22)=2 ##.
Observe that ## z(11)=1\implies 1=B(11)\cdot sin(\frac{11\pi}{2}+\frac{\pi}{3})\implies 1=B(11)\cdot (-\frac{1}{2})\implies B(11)=-2 ## and ## z(22)=2\implies 2=B(22)\cdot sin(11\pi+\frac{\pi}{3})\implies 2=B(22)\cdot (-\frac{\sqrt{3}}{2})\implies B(22)=-\frac{4\sqrt{3}}{3} ##.
Now we will define ## B(x)=-2z(x) ##, where ## z(x)=-sin(\frac{\pi\cdot x}{2})-\frac{2\sqrt{3}}{3}\cdot cos(\frac{\pi\cdot x}{2}) ##.
Hence, the periodic function is ## z(x)=(2sin(\frac{\pi\cdot x}{2})+\frac{4\sqrt{3}}{3}\cdot cos(\frac{\pi\cdot x}{2}))\cdot sin(\frac{\pi\cdot x}{2}+\frac{\pi}{3}) ##.
Above is the practice problem which you've given me, is this correct? And I agree that I made things more complicated than necessary but I actually like the way you think.
This is going in the wrong direction.
Lemma: A function ##y(x)=\sin(\omega \cdot x +a)## has always the least period ##\dfrac{2\pi }{\omega}. ##
Proof:
\begin{align*}
y\left(x+n\cdot\dfrac{2\pi}{\omega}\right)&=\sin\left(\omega\left(x+n\cdot\dfrac{2\pi}{\omega}\right) + a\right)\\
&=\sin\left(\omega x+ 2\pi n +a \right)\\
&=\sin((\omega x+a)+2\pi n)\\
&=\sin(\omega x+a) \cos(2\pi n)+\cos(\omega x+a) \sin(2\pi n)\\
&=\sin(\omega x+a)\cdot 1 + \cos(\omega x+a) \cdot 0\\
&=\sin(\omega x+a)\\
&=y(x)
\end{align*}
Every function of period ##p## is also a function of period ##2p,3p,4p,\ldots## So we want to show now, that ##\dfrac{2\pi }{\omega}## is the least period. To do that, we first note that ##x= \dfrac{n\pi - a}{\omega}## are zeros of ##y(x)## for all integers ##n## so that the period could possibly be ##\dfrac{(n+1)\pi - a}{\omega}-\dfrac{n\pi - a}{\omega} = \dfrac{\pi}{\omega}.## We therefore calculate the slope at these points.
y'(x)=\cos (\omega \cdot x +a)\cdot (\omega \cdot x +a)'= \omega \cos (\omega \cdot x +a)
\begin{align*}
y'\left(\dfrac{-1\cdot\pi - a}{\omega}\right)&=\omega \cos \left( -\pi \right)=-\omega \\
y'\left(\dfrac{0\cdot\pi - a}{\omega}\right)&=\omega \cos \left( 0 \right) =\omega\\
y'\left(\dfrac{1\cdot\pi - a}{\omega}\right)&=\omega \cos \left( \pi \right) =-\omega
\end{align*}
This means, say that ##\omega > 0,## that ##y(x)## is always decreasing at the points ##x= \dfrac{(2n+1)\pi - a}{\omega}## and always increasing at ##x= \dfrac{2n\pi - a}{\omega}.## The period is thus at least
\dfrac{(2n+1)\pi - a}{\omega}-\dfrac{(2n-1)\pi - a}{\omega}=\dfrac{2\pi}{\omega}
##\square##​
This means in our case with ##\omega=\dfrac{\pi}{2}## that we have a period of ##\dfrac{2\pi }{\omega}=\dfrac{2\pi }{\frac{\pi}{2}}=\dfrac{2}{\frac{1}{2}}=4.##
The period cannot be ##3.## I leave it up to you to find the exact point where your argument went wrong. The amplitude ##B(x)## must also be chosen with period ##4,## i.e. such that ##B(x)=B(x+4n).##
This is correct.
We must have ##B(11)=-2## and ##B(22)=-\dfrac{4\sqrt{3}}{3}=-\dfrac{4}{\sqrt{3}}.##
However, we also need the above condition that ##B(x)## is of period ##4##, i.e. that ##B(x)=B(x+4n)## for all ##n\in \mathbb{Z}.## You should be able by now to find such a periodic function ##B(x).##
Math100 said:
Now we will define ## B(x)=-2z(x) ##...
What do you mean?
We defined ##z(x)=B(x)\cdot \sin\left(\dfrac{\pi\cdot x}{2}+\dfrac{\pi}{3}\right).## By setting ##B(x)=-2z(x) ## we would get
\begin{align*}
0&= B(x)\cdot \left(1+2\sin\left(\dfrac{\pi\cdot x}{2}+\dfrac{\pi}{3}\right)\right) \\
0&=B(22)\cdot \left(1+2\sin\left(\dfrac{\pi\cdot 22}{2}+\dfrac{\pi}{3}\right)\right)=-\dfrac{4}{\sqrt{3}}\cdot\left(1+2\cdot \left(-\dfrac{\sqrt{3}}{2}\right)\right)=-\dfrac{4}{\sqrt{3}}+4 \neq 0
\end{align*}
You defined ##B(x)## by using ##z(x)## but ##z(x)## is defined by ##B(x)## which is circular. And if ##B(x)\neq 0## we would have ##1=-2\sin\left(\dfrac{\pi\cdot x}{2}+\dfrac{\pi}{3}\right)## which can be solved for ##x.## We would be left with only a subset of all real numbers, but we want ##z(x)## to be defined everywhere.
You can use the sine term of the function ##z(x)## as a function of period ##4,## i.e. ##s(x):=\sin\left(\dfrac{\pi\cdot x}{2}+\dfrac{\pi}{3}\right).## However, ##s(11)=-\dfrac{1}{2}=\dfrac{1}{4}B(11)## and ##s(22)=-\dfrac{\sqrt{3}}{2}=-\dfrac{3}{2\sqrt{3}}=\dfrac{3}{8}B(22).## This means we have to adjust ##s(x).## I think the method in post #6 doesn't work in this case. So my first ansatz in the thread might be faster than shifting the wave to the right or to the top.
What we need is a function ##B(x)## with
B(x)=B(x+4n)\text{ for all }n\in \mathbb{Z}\;\wedge\; B(11)=-2\;\wedge\; B(22)=-\dfrac{4}{\sqrt{3}}
I would make an ansatz ##B(x)=p\cdot \sin\left(\dfrac{\pi\cdot x}{2}\right)+q\cdot \cos\left(\dfrac{\pi\cdot x}{2}\right).## This guarantees a period of ##4## by the Lemma, and we have two unknowns ##p,q## and two equations ##B(11)=-2## and ##B(22)=-\dfrac{4}{\sqrt{3}}.##
(I hope I made no serious typos, mistakes, or oversaw something. It's late here.)
Periodicity mod 4 requires f(4n + 3) = 1 and f(4n + 2) = 2. So you just need to choose values for f elsewhere on 0 \leq x &lt; 4 and extend it to the rest of the domain by periodicity. Another solution, which also works for a real domain, is <br /> f(x) = \begin{cases} 4 - x &amp; 0 \leq x &lt; 4 \\<br /> &amp;\vdots \\<br /> 4(n+1) - x, &amp; 4n \leq x &lt; 4(n+1) \\<br /> &amp;\vdots \end{cases}
Proof:
\begin{align*}
&=y(x)
\end{align*}
\begin{align*}
\end{align*}
##\square##​
This is correct.
What do you mean?
\begin{align*}
\end{align*}
I see where I went wrong in my argument and that the period must be ## 4 ##. Also, I have found out that ## B(x)=2sin(\frac{\pi\cdot x}{2})+\frac{4\sqrt{3}}{3}\cdot cos(\frac{\pi x}{2}) ##.
Yes, that's right. So
z(x)=B(x)\sin\left(\dfrac{\pi x}{2}+\dfrac{\pi}{3}\right)\wedge B(x)=2\sin\left(\dfrac{\pi x}{2}\right)+\dfrac{4}{\sqrt{3}} \cos\left(\dfrac{\pi x}{2}\right)
Can you simplify the formula for ##z(x)## by using trigonometric formulas and determine the (least) period of ##z(x)##? How can we change ##z(x)## so that ##z(11)=1\, , \,z(22)=2## and ##z(x)=z(x+4n)## still hold?
Yes. It's ## z(x)=(2sin(\frac{\pi x}{2})+\frac{4\sqrt{3}}{3}\cdot cos(\frac{\pi x}{2}))\cdot sin(\frac{\pi x}{2}+\frac{\pi}{3})=2sin(\frac{\pi x}{2})\cdot sin(\frac{\pi x}{2}+\frac{\pi}{3})+\frac{4\sqrt{3}}{3}\cdot cos(\frac{\pi x}{2})\cdot sin(\frac{\pi x}{2}+\frac{\pi}{3})=cos(-\frac{\pi}{3})-cos(\pi x+\frac{\pi}{3})+\frac{2\sqrt{3}}{3}(sin(\pi x+\frac{\pi}{3})+sin(\frac{\pi}{3}))=\frac{1}{2}-cos(\pi x+\frac{\pi}{3})+\frac{2\sqrt{3}}{3}(sin(\pi x+\frac{\pi}{3})+\frac{\sqrt{3}}{2})) ## and the least period is ## 2 ##.
This is correct. The period is ##\dfrac{2\pi }{\pi}=2.## And if ##z(x)=z(x+2m)## we automatically have ##z(x+4n)=z(x+2\cdot (2n))=z(x+2m)=z(x).## Period two implies period four.
The simplification could be better:
So
\begin{align*}
\sin\left(\dfrac{\pi x}{2}+\dfrac{\pi}{3}\right)&=\sin\left(\dfrac{\pi x}{2}\right)\cos\left(\dfrac{\pi}{3}\right)+
\cos\left(\dfrac{\pi x}{2}\right)\sin\left(\dfrac{\pi}{3}\right)\\
&=\dfrac{1}{2}\sin\left(\dfrac{\pi x}{2}\right)+\dfrac{\sqrt{3}}{2}\cos\left(\dfrac{\pi x}{2}\right)
\end{align*}
and
\begin{align*}
z(x)&=\left(2\sin\left(\dfrac{\pi x}{2}\right)+\dfrac{4}{\sqrt{3}} \cos\left(\dfrac{\pi x}{2}\right)\right)\cdot\left( \dfrac{1}{2}\sin\left(\dfrac{\pi x}{2}\right)+\dfrac{\sqrt{3}}{2}\cos\left(\dfrac{\pi x}{2}\right)\right)\\
&=\sin^2\left(\dfrac{\pi x}{2}\right)+\dfrac{5}{\sqrt{3}}\sin\left(\dfrac{\pi x}{2}\right)\cos\left(\dfrac{\pi x}{2}\right)+2\cos^2\left(\dfrac{\pi x}{2}\right)\\
&=1+\cos^2\left(\dfrac{\pi x}{2}\right)+\dfrac{5}{2\sqrt{3}}\sin\left(\pi x\right)\\
&=1+\left(\dfrac{1+\cos\left(\pi x\right)}{2}\right)+\dfrac{5}{2\sqrt{3}}\sin\left(\pi x\right)\\
&=\dfrac{3}{2}+\dfrac{1}{2}\cos\left(\pi x\right)+\dfrac{5}{2\sqrt{3}}\sin\left(\pi x\right)
\end{align*}
Since we have ##\sin\left(\pi \cdot 11\right)=\sin\left(\pi \cdot 22\right)=0##, we can drop that term because it doesn't contribute to ##z(11)## or ##z(22).##
The new function is thus ##z_0(x)=\dfrac{3}{2}+\dfrac{1}{2}\cos\left(\pi x\right).##
What a long and winding road to end up with such a simple cosine function!
So
\begin{align*}
\end{align*}
and
\begin{align*}
\end{align*}
The final new function looks a lot simpler.
