How to correctly tap hole by use both drill and tap bit
  • Thread starter Thread starter abdulbadii
    Bit Drill Hole
To correctly tap a hole using a combined drill and tap bit, the tool must move in a full clockwise cycle followed by a half counter-clockwise cycle. This method is suitable for soft materials like plastics, aluminum, and composites, but not for deep holes or hard materials. The process allows for drilling and threading in one pass, typically using a cordless handheld drill with lubrication such as soap or cutting fluid. It is crucial for the drill to exit the material before the tap engages to prevent shearing off the threading section. Proper technique ensures effective hole tapping without damaging the bit or material.
abdulbadii
TL;DR Summary
How do we correctly tap hole by use a both drill and tap bit
How to correctly tap hole, i.e. make thread inside it, by use a usual drill with bit having 2 in 1 i.e. both bore/drill and tap bit once as in hole tap the rule is it must always go back and forth full cycle clockwise and half cycle counter-clockwise direction, so how can this rule in the former use ?
The combined drill and tap is for use in soft sheet materials such as plastics, aluminium or composites. It is not designed to be used for deep holes, or for hard materials. The hole is drilled and threaded in one pass, without backing the tap. A cordless handheld drill is often used, with some form of soap or cutting fluid to lubricate the tap.
When drilling-tapping in metal, that type is to be used for limited thickness walls or sheetmetal.
The drill part should exit the opposite side of the wall prior to the tap part engages.
The reason is that drilling requires less advance and the tap, and the threading section can easily shear off is drilling and tapping happens simultaneously.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
