I How to derive orbital angular momentum of spins in quantum mechanics?
geelpheels
TL;DR Summary
Make up for some lost things in Griffiths QM 3rd Ed. Equation (4.134) in Griffiths QM 3rd Ed. was given but no explanation. Please explain how to derive this equation in detail or provide references that by reading them one can understand how it is derived.
Thanks in advance.
Assuming you mean this equation: ##[S_i,S_j]=i\hbar\epsilon_{ijk}S_{k}##
Some quick searching on google (thanks @fresh_42 for the google pdf searching tips - they're helping, a lot), I found this, which seems like it uses the classical ##\vec L = \vec r \times \vec p## to derive the equation, and I was able to follow it pretty easily despite not knowing nearly enough QM to actually use/apply the equation: https://www2.ph.ed.ac.uk/~ldeldebb/docs/QM/lect8.pdf
This one I don't understand - but just from a quick skim over it appears to be more thorough than the first source. It starts off with a similar approach but then seems to use Hamiltonians (?). Maybe it is just fully proving everything. When the first source said "it can be proven that [...]" I just took it for granted, but maybe if you want something more thorough and have the maths/physics knowledge to understand this, then this one is the way to go: https://people.ee.duke.edu/~jungsang/ECE590_01/LectureNotes1.pdf
(maybe I am not the best person to answer this question though. I have never seen this equation before in my life, or at least if I have I don't remember it. My physics is not this level. Just trying to help out.)
In the footnote just before these equations, Griffiths explains that he will take the commutation relations ##[S_x, S_y]=i\hbar S_z## (etc.) for spin operators as postulates of the theory, meaning he will not derive these relations but just adopt them as they are. In this same footnote, he suggests another QM textbook in which apparently you can find the derivation of these commutation relations. So you can check that out first.
Physically speaking, one of the experimental proofs that spin ##\mathbf{S}## is a form of angular momentum (and hence that it should satisfy the same commutation relations that the orbital angular momentum ##\mathbf{L}## does) is the so-called Einstein-de Haas effect (https://en.wikipedia.org/wiki/Einstein–de_Haas_effect) in which magnetizing a body causes it to rotate.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
