How to determine a basis given a set of vectors?
dmitriylm
Let V be the subspace spanned by the following vectors:
[ 0]...[ 1 ]...[2]
[ 2]...[ 1 ]...[5]
[-1]...[3/4]...[0]
Determine a basis for V.
I'm not quite sure how to start here. Would placing the vectors in a matrix and deriving its reduced echelon form give me a basis?
[ 0]...[ 1 ]...[2]
[ 2]...[ 1 ]...[5]
[-1]...[3/4]...[0]
Are these row vectors or column vectors?
These are column vectors.
If the three vectors are linearly independent, they are your basis. If they're linearly dependent, some subset of them will be your basis.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
