How to determine whether the preimage of a point is a imbedding submanifold?
  • Thread starter Fangyang Tian
  • Tags
    Point
In summary, the preimage of a critical point can be an embedded submanifold, but this is dependent on the definition of the inverse image and the structure of the mapping. In some cases, the inverse image may not be a manifold at all, but can be reduced to one by considering the finer structure.
Fangyang Tian
How to determine whether the preimage of a point is a imbedding submanifold??
Dear Folks:
It is well known that the preimage of a regular point is a imbedding submanifold, but is it possible that the preimage of a critical point is also a imbedding submanifold?? More generally, is there a prosedure to determine when the preimage of a point is a imbedding ??
Many thanks!
It is possible that the preimage of a critical point is an embedded submanifold. For instance, consider the map f:R²-->R : (x,y) --> y² and let M:=graph(f)={(x,y,z) in R³ | z=f(x,y)=y²} This is the manifold that you get by taking a parabola parabolla in the yz plane and "sliding" it along the x-axis so as to have one such parabola standing on each point (x,0,0). Now let h:M-->R be the height function h(x,y,z)=z. Then h-1(0)=R x {0} x {0} is an embedded submanifold, but each point of h-1(0) is critical because the derivative of h vanishes there.
This example only works with a special definition of the inverse image of a point, and to some extent an artificial one. In algebraic geometry, and even in analytic geometry, when one studies sets more complicated than manifolds, i.e. when one studies both manifolds and non manifolds, one does not assume the structure of an inverse image is defined only by the set of points but by the function defining the map. Thus in this example the correct structure on the inverse image is defined by setting z= y^2 = 0. this defines an analytic variety which is not the same as the manifold defined by y=0, but the "double" of that variety. The situation is clarified by looking at y^2 = t and letting t-->0. These are all manifolds for t≠0, but as t-->0 they come together to form a variety which is actually not a manifold anywhere, but everywhere singular. It is only when one takes the "reduced" structure on this variety that one obtains a manifold. So the answer is that yes the inverse image set of a critical point can look like a manifold, but only if one ignores the finer structure contained in the mapping.
FAQ: How to determine whether the preimage of a point is a imbedding submanifold?
How do you define an imbedding submanifold?
An imbedding submanifold is a subset of a higher-dimensional manifold that can be embedded in the manifold in a one-to-one and onto manner, while still maintaining its own topological and smooth structure.
What is the importance of determining whether a point is a imbedding submanifold?
Determining whether a point is a imbedding submanifold is important in understanding the local structure of a manifold and its relationship to the surrounding space. It also allows for the study of functions and their properties on the submanifold.
What are some methods for determining if a point is a imbedding submanifold?
Some methods for determining if a point is a imbedding submanifold include the use of charts and local coordinates, the inverse function theorem, and the implicit function theorem. These methods involve checking for certain conditions and properties that characterize an imbedding submanifold.
Can a point be a imbedding submanifold in more than one way?
No, a point can only be a imbedding submanifold in one way, as it is a single point and cannot have multiple topological or smooth structures. However, a point can be a imbedding submanifold in multiple higher-dimensional manifolds.
How does the concept of imbedding submanifolds relate to the larger field of differential geometry?
The study of imbedding submanifolds is an important aspect of differential geometry, which is concerned with the study of smooth manifolds and their properties. Imbedding submanifolds allow for the study of functions and their properties on a subset of a manifold, and can provide insight into the overall structure of the manifold.
