How to estimate enthalpy change across a compressor in simple vapor compression cycle
To estimate the enthalpy change across a compressor in a vapor compression cycle using R134a, one can analyze the conditions before and after the compressor, specifically from point H1 to H2. The outlet enthalpy (H2) can be estimated using the compressor's displacement and RPM to calculate the mass flow rate, alongside the power input for enthalpy increase. It is important to consider that if the compressor operates adiabatically, the inlet and outlet entropy will remain approximately constant. For obtaining R134a property data, resources such as manufacturer data, thermodynamic tables, and engineering textbooks are recommended. Accurate calculations depend on understanding the system's heat load and the compressor's operational characteristics.
bobkokke
TL;DR Summary
Calculate compressor side of a Vapour compression cycle without knowing output of the compressor.
Hi everyone,
I'm fairly new to HVACR systems and currently doing research on building an estimation model of a basic vapor compression cycle.
Right now, I'm trying to calculate the enthalpy change across the compressor — from point H1 (before the compressor) to point H2 (after the compressor). For my test setup, I’m assuming R134a as the refrigerant, with an inlet pressure of 2 bar. (if possible well asume 5K superheating)
As a reference, I’m using a Bitzer 2DC-3.2Y-40S compressor, but I don’t yet have outlet pressure or temperature data.
My questions are:
  • How can I estimate the outlet enthalpy (H2) in this situation?
  • Can I use the compressor's displacement and RPM to estimate the mass flow rate, and then use power input to find enthalpy increase?
  • Are there any tools or databases you recommend for getting R134a property data?
Any help or guidance would be greatly appreciated!
The mass flow rate is determined by the heat load of the overall system. Are you saying that you have no idea what the outlet conditions of the compressor are. If the compressor is operating adiabatically (and nearly reversibly), the inlet entropy- and outlet entropy per unit mass will be about the same. So you move on a constant entropy line for the compressor.
You can get thermodynamic data on 134a either from the manufacturer (e.g., DuPont) of probably from tables in Fundamentals of Engineering thermodynamics by Moran et al. There should be table online of 134a thermodynamic data also.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
