How to Express Non-regular Prior Distributions by Mathematical Formula
  • I
  • Thread starter nizi
  • Tags
    Support
nizi
This time I target the following two-class Bayesian logistic regression as statistical models.
$$y_n \sim \mathrm{Bernoulli}(q_n)$$
$$q_n = \sigma (\beta_0 + x_n \beta_1)$$
where ##n## is the index of the data and ##\sigma## is the logistic function.
Since I assume ##\beta_0 + x_n \beta_1## as the linear predictor (the independent variable of the logistic activation function), I have two parameters ##\beta_0## and ##\beta_1##, and I want to express that their prior distributions independently follow a non-regular uniform distribution, the support of which each probability density function is the set of real numbers.
Is it appropriate to write
$$\beta_0, \beta_1 \sim \mathrm{Uniform}(-\infty, \infty), i.i.d.$$
in this case?
I'm particularly concerned about the appropriateness of writing i.i.d.
If there is a more appropriate way to express this, please let me know.
The iid is fine. But this prior will require some justification. The uniform distribution will be really bad here because it has no tails so the posteriors are almost guaranteed to be unreliable. And starting with this prior is numerically impossible. And approximating it will probably have poor convergence.
If you do use this prior you will need to provide rock-solid theoretical arguments why the priors must come from a uniform distribution and none other. And if you have that much information then surely the non-regular version is not correct.
Likes WWGD
I appreciate your thought-provoking response very much.
My question has been answered.
What I was particularly concerned about is whether I can use the term "i.i.d." here, even thought ##x_n## has certain units, e.g. kg.
This is because the units of ##\beta_0## and ##\beta_1## are different in this case.
As you mentioned, it's impossible to use this improper prior in a numerical simulation, so it's only an mathematical expression.
Likes Dale
  • Math Proof Training and Practice
16K
  • STEM Academic Advising
9K
