How to find a polynomial from an algebraic number?
  • Thread starter Thread starter guysensei1
    Polynomial
To find a polynomial with integer coefficients that has an algebraic number like √2+√3+√5 as a root, one can use techniques involving the manipulation of expressions and identities. The discussion highlights methods for simplifying complex algebraic numbers by eliminating surds through repeated application of algebraic identities. For instance, using the identity (b - a)(b + a) = b^2 - a^2 can help in constructing polynomials step by step. The conversation also emphasizes the importance of ensuring that the final polynomial has integer coefficients and addresses potential mistakes in calculations. Ultimately, the correct polynomial can be confirmed through computational tools like Wolfram Alpha.
guysensei1
Given some algebraic number, let's say, √2+√3+√5, or 2^(1/3)+√2, is there some way to find the polynomial that will give 0 when that number is substituted in? I know that there are methods to find the polynomial for some of the simpler numbers like √2+√3, but I have no clue where to begin for the more complex ones like the 2 I listed above.
Mathematics news on Phys.org
Do you impose any restirictions on the polynomial you are looking for? The way you stated your problem P(x)=x-a where a is your number will do. Or even P(x)=0. I guess that's not what you were looking for though, so you need to make your question more precise.
Remember that every polynomial s.t.: P(a)=0 has form P(x)=(x-a)*Q(x) where Q is another polynomial. So you can start by writing it that way and thinking what Q do you need for your polynomial to do the job. My guess is that you want to restrict yourself only to polynomial with integer coefficients, which is hinted by the fact that you explicitly stated that zeroes are algebraic. In this case Viete formulas might help you.
Gah, I should have said that all the coefficients must be integers, and P(x)=0 is not allowed. :P
Repeated use of (b - a)(b + a) = b^2 - a^2 helps. Thus with b = x - \sqrt 2 - \sqrt 3 and a = \sqrt 5 we obtain (x - \sqrt 2 - \sqrt 3 - \sqrt 5)(x - \sqrt 2 - \sqrt 3 + \sqrt 5) = x^2 - 2(\sqrt 2 + \sqrt 3)x + 2\sqrt 6 = p(x) and the \sqrt 5 is gone. Now using the same trick with b = x^2 + 2\sqrt 6 and a = 2(\sqrt 2 + \sqrt 3) (I make this choice because (\sqrt 2 + \sqrt 3)^2 = 5 + 2\sqrt 6 and I already have a \sqrt 6 anyway) yields<br /> q(x) = p(x)(x^2 + 2\sqrt 6 + 2(\sqrt 2 + \sqrt 3)x) = x^4 - 8\sqrt 6 x^2 - 20x^2 + 24 and only the \sqrt{6} remains. Applying the trick once more yields<br /> r(x) = q(x)(x^4 - 20x^2 + 24 + 8\sqrt{6}x^2) = (x^4 - 20x^2 + 24)^2 - 384x^4<br /> and all the surds are gone.
Similarly, for 2^{1/2} + 2^{1/3} one can make use of b^3 - a^3 = (b - a)(b^2 + ab + a^2) by setting b = x - \sqrt 2 and a = 2^{1/3}: <br /> (x - \sqrt 2 - 2^{1/3})((x - \sqrt{2})^2 + 2^{1/3}(x - \sqrt 2) + 2^{2/3})<br /> = (x - \sqrt{2})^3 - 2. (Alternatively one can observe that (\sqrt 2 + 2^{1/3} - \sqrt 2)^3 = 2.) Working what one should multiply (x - \sqrt{2})^3 - 2 by to obtain a polynomial with integer coefficients I leave as an exercise.
This equation (when equated to 0) does not have √2+√3+√5 as a root. I think there's a mistake, but I can't find it.
It should be (x^4 - 20x^2 + 24)^2 - 96x^4, on account of the fact that (4\sqrt{6})^2 = 96, not 384.
(Woolfram alpha confirms that \sqrt 2 + \sqrt 3 + \sqrt 5 is a root.)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
