How to find the force of particles
  • Thread starter Thread starter itsmarasilly
    Force Particles
To find the force between two charges of 1.9 x 10^-5 C separated by 11 cm, use Coulomb's law: F = k(q1*q2)/r^2. Here, k is Coulomb's constant (9 x 10^9 N m²/C²), and r is the distance in meters (0.11 m). The force calculated will be equal for both charges, with each force directed towards the other charge due to their opposite signs. The charges attract each other, resulting in equal magnitudes of force acting in opposite directions. Understanding the symbols in the equation is crucial for correctly applying Coulomb's law.
itsmarasilly
A positive and a negative charge, each of magnitude 1.9 multiplied by 10^-5 C, are separated by a distance of 11 cm. Find the force on each of the particles.
F = kq^2/r^2
r = sqrt(kq1q2/F)
i'm not sure which numbers are placed where in each equation :(
Can you start by explaining what each of the symbols in the first equation mean?
r stands for culomb's law(?), and I'm not quite sure about the others..
r stands for radius which is the distance between the two charges.
k is the columbs constant = 9x10^9
q represents the charges. We actually ignore if its positive or negative at this point so we can say q^2
normally it would be (q1)(q2) / r^2
F = kq^2/r^2 = (9 x 10^9) [(1.9 x 10^-5)^2 / (.11 m)^2)]
that should be the force of attraction between the two
so the force on one of the charges should point in the direction of the other charge
the force on the other charge should point towards the first charge. They should
both be of equal value other than positive and negative.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
