I How to find the location of red cells?
  • I
  • Thread starter Thread starter MarkSS
    Cells
Mark seeks assistance in predicting values in red cells based on known values in green cells for his final work. He has observed a high correlation between analytical calculations and measured values but is unsure how to derive the red cell values or their positions. The discussion suggests using a statistical model to establish the relationship between the red and green cells, employing a least-squares fit for predictions. Clarification is requested regarding the terminology used for the positions of the green cells. The conversation also questions whether this topic overlaps with another existing discussion.
MarkSS
TL;DR Summary
HOW TO FIND THE LOCATION OF RED CELLS??
Hi ALL!
I’m Mark. I’m new on this forum. Thank you very much to possibility of registration. This is my first post over here. I am student and I am writing my final work. I have a big and serious technical problem. Maybe some of you will be able to help me.
I show results of my measurements in tables.
TABLE LEGEND:
X
- The X marks are measured values. The results of my measurements (KNOWN VALUES)
GREEN (KNOWN VALUES) - In green cells with numbers from 1 to 6 there are results of analytical calculations from previous series of measurements.
RED (VALUES TO PREDICT) - In red cells with letters from A to F are results of current calculations.
I noticed that results of analytical calculations agreed with measured values:
values of green from 1 to 6 and values of red cells from A to F. High correlation of the results of analytical calculations and measurements
MY PROBLEMS:
How to predict values in red cells?
How to find variants of value in red cells when I have position green cells in sheet ??.
OR
How to find variants of positions of red cells when we have position green cells in sheet from previous calculations??
Regards
Mark
You need some statistical model of how the values of the red cells depend on the values of the green cells. Then you do a statistical fit to that model, usually a least-squares fit.
Similarly you would need a statistical model of how the position of the red cell depends on the position of the green cells. Again, you would do a fit to that model.
I am guessing that:
S1, S2, S3 ... refer to test samples.
M1, M2,M3, ... refer to types of measurements of the samples (for example pH, height, mass, viscosity, ...)
1, 2, 3, 4: refer to four separate opportunities to apply the same measurement to the same sample.
I am not clear of the phrase "position green cell".
Do you mean "the positions of green cells"? Or simply "some green cells"?
Also, is this a duplicate of:
https://www.physicsforums.com/threads/prediction-problem.1049901/
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
