How to Find the Normal Vector for a Plane Perpendicular to Another?
To find the scalar equation of a plane perpendicular to another with a normal vector of [3,1,2], one must determine a normal vector for the new plane. The vector from point A(2,-6,-1) to point B(1,2,-4) is calculated as [-1, -4, -3], which lies in the new plane. The required normal vector for the new plane can be found using the cross product of the vectors [3,1,2] and [-1,-4,-3]. The cross product will yield a vector that is perpendicular to both, providing the necessary normal vector for the scalar equation. Understanding the properties of the cross product is essential for solving this problem.
eme_girl
Find the scalar eq'n of a plane that is perpendicular to the plane with normal vector [3,1,2] and passes through points A(2,-6,-1) and B(1,2,-4).
I think that the normal vector can be the direction vector of this new plane. But then, in order to find the scalar eq'n I need a normal vector of this new plane. How do I find this?
Strictly speaking a plane doesn't have a "direction vector". What is true is that the vector [3,1,2] is in the plane you want. You also know that the vector from A(2,6,-1) to B(1,2,-4) (which is, of course, [1-2,2-6,-4-(-1)]= [-1, -4, -3] is in the plane. Do you know how to find a vector that is perpendicular to both [3,1,2] and [1,4,-3]?
I understand what you just found. But no, I do not know how to find a vector's that perpendicular to both those vectors.
eme_girl,
do u know the direction of a vector that is a cross product of two vectors?
-- AI
TenaliRaman's point: the cross product of two vectors is always perpendicular to both.
The cross product of [a1,a2,a3] and [b1,b2,b3] is the vector [a2b3-a3b2,a3b1-a1b3,a1b2-a2b1].
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
