MHB How to find the value of f'(x) at c
  • Thread starter Thread starter rahulk1
    Value
To find the value of f'(x) at a specific point c, the definition of the derivative is applied: f'(x) = lim(h→0) [f(x+h) - f(x)] / h. For f(x) = sin(x), the derivative simplifies to f'(x) = cos(x). When c = π/4, this results in f'(π/4) = cos(π/4) = √2/2. Similarly, for f(x) = cos(x), the derivative is also f'(x) = -sin(x), leading to specific evaluations at given points. The discussion emphasizes using limits and trigonometric identities to derive these results.
rahulk1
How to find the value of f'(x) at cif
1. f(x)=sinx, c=pi/4
2. f(x)=sinx, c=3pi/2
3.2. f(x)=cosx, c=0, pi/2, pi, 3pi/2, 2pi
Mathematics news on Phys.org
Since you posted in the Pre-Calculus forum, I suppose you are to use the definition:
$$f'(x)\equiv\lim_{h\to0}\frac{f(x+h)-f(x)}{h}$$
So, for $f(x)=\sin(x)$, we have:
$$f'(x)\equiv\lim_{h\to0}\frac{\sin(x+h)-\sin(x)}{h}$$
Using the angle-sum identity for the sine function, we may write:
$$f'(x)=\lim_{h\to0}\frac{\sin(x)(\cos(h)-1)+\cos(x)\sin(h)}{h}$$
$$f'(x)=\sin(x)\lim_{h\to0}\frac{\cos(h)-1}{h}+\cos(x)\lim_{h\to0}\frac{\sin(h)}{h}$$
$$f'(x)=\sin(x)\lim_{h\to0}\frac{\cos^2(h)-1}{h(\cos(h)+1)}+\cos(x)\lim_{h\to0}\frac{\sin(h)}{h}$$
Using a Pythagorean identity on the first limit on the RHS, we obtain:
$$f'(x)=-\sin(x)\lim_{h\to0}\frac{\sin^2(h)}{h(\cos(h)+1)}+\cos(x)\lim_{h\to0}\frac{\sin(h)}{h}$$
$$f'(x)=-\sin(x)\lim_{h\to0}\frac{\sin(h)}{h}\cdot\lim_{h\to0}\frac{\sin(h)}{(\cos(h)+1)}+\cos(x)\lim_{h\to0}\frac{\sin(h)}{h}$$
Using the fact that $$\lim_{u\to0}\frac{\sin(u)}{u}=1$$, we have:
$$f'(x)=-\sin(x)(1)(0)+\cos(x)(1)=\cos(x)$$
Can you now obtain a result for $f(x)=\cos(x)$?
Hi
Thanks for your suggestion
But what about c=pi/4 where are used
c=pi/4 in the answer
rahulk said:
Hi
Well, if $f'(c)=\cos(c)$ and $$c=\frac{\pi}{4}$$...then what do you get?
How sin(h)/(cos(h)+1 =0 please descibe
$$\lim_{h\to0}\frac{\sin(h)}{\cos(h)+1}=\frac{\sin(0)}{\cos(0)+1}=\frac{0}{1+1}=0$$ :D
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
