MHB How to Find Values of k for Equations with One Real Root?
  • Thread starter Thread starter mathdad
To find values of k for equations with exactly one real root, the discriminant must be set to zero using the formula b² - 4ac = 0. For the equation 3x² + (√(2k))x + 6 = 0, the discriminant involves the coefficient of x, which is √(2k). Similarly, for kx² + kx + 1 = 0, the discriminant must also equal zero to ensure a single real root. Both equations require solving for k to meet this condition. The application of the discriminant is essential for determining the values of k that yield one real root.
mathdad
Find values of k such that the equation has exactly one real root.
1. 3x^2 + (sqrt{2k})x + 6 = 0
2. kx^2 + kx + 1 = 0
Question:
Do the questions above involve the discriminant?
If so, I must apply b^2 - 4ac = 0, right?
Mathematics news on Phys.org
Question:
Yes . you can solve with discriminant and you must apply $b^2-4ac=0$
Not too bad.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
