How to find which of three points are on a line?
  • Thread starter Thread starter rocapp
    Line Points
rocapp
Which of these three points falls on the line?
l: r(t)=(i+2j)+t(6i+j-5k)
P(1,2,0); Q(-5,1,5); R(-4,2,5)
I have the answer, but I don't understand why P and Q fall on the line but R does not. Is it because the i and j magnitudes are different for R?
P:
(1+6t) = 1
t=0
2=2+t
t=0
t=0
Q:
-5=1+6t
t=-1
1=2+t
t=-1
t=0
R:
-4=1+6t
t=-5/6
2=t+2
t=0
t=0
First, you are right that P and Q fall on the line and R does not. And as you see, R is not on the line because using those points you get 3 incompatible equations in t.
Whether a point falls on a line depends on all 3 magnitudes, i, j and k, and the trivial answer to your question is that most combinations will not work i.e. most 3 dimensional points are not on any given line.
However, working backwards from the equation we can get some insight. For example r(0) = i + 2j. So the point that fits there is P = (1,2,0). When you look at r(-1) = -5i + j - 5k, you see that Q = (-5,1,-5) is a point on the line.
But your incompatible equation for R tells you that there is no possible t for which r(t) = R. It's not really deeper than that.
Thanks! I think I understand, but what about the t=0 in R? Does this value not count since there is already an incompatible value in its components?
P:
(1+6t) = 1
t=0
2=2+t
t=0
t=0
Q:
-5=1+6t
t=-1
1=2+t
t=-1
t=0
R:
-4=1+6t
t=-5/6
2=t+2
t=0
t=0
The line has parametric equations x = 1 + 6t, y = 2 + t, z = -5t. A point (a,b,c) lies on the line if the equations a = 1+6t, b = 2+t, c = -5t are compatible; that is, we must get the same t from all three equations.
Thanks a bunch! That's what I needed.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
