How to get the density equation using the Reidel Equation for vapor liquids?
The discussion centers on calculating the density of fluid using the Riedel Equation for vapor-liquid systems. The primary focus is on deriving a function to compute liquid phase density for numerical modeling. A reference is mentioned that suggests using critical properties of each component in the Riedel correlation from 1954, specifically as a function of temperature. However, the empirical function needed for these calculations is not provided in the reference, prompting the need for further clarification on how to implement the Riedel Equation effectively in this context.
maryelin
TL;DR Summary
how to calculate density of fluid using the Reidel equation.n
I need to know how to get the density equation using the Reidel Equation for vapor liquids... how is the calculations to get
Chemistry news on Phys.org
maryelin said:
TL;DR Summary: how to calculate density of fluid using the Reidel equation.n
You are looking for the density at the critical point?
No, I need find a function that compute the liquid phase density for use in my numerical model. I have found a reference who do says "we compute the density of oil component by substituting the critical properties of each component into Riedel correlation (1954) as a function of temperature" but they don't present the empirical function
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
