srfriggen
- 307
- 6
- Homework Statement
- Sketch a graph, without the use of a calculator, y=log((x/(x+2))
- Relevant Equations
- y=log((x/(x+2))
I first attempted to find the x and y intercepts, algebraically, and discovered there were none. I then split the equation into y= log(x) - log(x+2) to see if that would give me any insight. It did not.
I used a graphing calculator and saw many similarities between x/(x+2) and log((x/(x+2)) but cannot make the leap to the latter.
I'm now considering the end behavior for the inner function and realizing there is a horizontal asymptote of y = 1. That means the end behavior of the outer function must have a horizontal asymptote at 0, since we are evaluating numbers closer and closer to 1 with the log function.
There is a vertical asymptote as x = -2
I think now I just need to test some points to see where the function is positive or negative.
And I just realized there must be an asymptote where the inner function is zero, i.e. x = 0. So I just tested some points and found the answer.
