How to integrate 1/x^2 (1 - x^2)
  • Thread starter teng125
  • Tags
    Integrate
In summary, the form for integrating 1/x^2 (1-x^2) is \frac{Ax+B}{x^2}+\frac{Cx+D}{1-x^2}. It is always a polynomial with one order lower, and can be solved for x by plugging in at least 4 values of x and solving for B, C, and D.
teng125
416
May i know how to integ 1/x^2 (1-x^2) ??
i try to form Ax/x^2 + Bx+C/(1-x^2) but can't get the answer...
the answer is-1/x + 1/2 ln (1+x) - 1/2 ln (1-x).pls help...
use latex already!
anyway, the form should be [tex]\frac{Ax+B}{x^2}+\frac{Cx+D}{1-x^2}[/tex]
its alway a polynom with one order lower...
fargoth said:
use latex already!
In fact, you should notice that 1 - x2 = (1 - x) (1 + x).
So partial fraction it gives:
[tex]\frac{1}{x ^ 2 (1 - x ^ 2)} = \frac{A}{x} + \frac{B}{x ^ 2} + \frac{C}{1 - x} + \frac{D}{1 + x}[/tex].
There are several ways to do this:
The most common way is to multiply both sides by x2(1 - x2), you'll have:
[tex]1 = Ax(1 - x ^ 2) + B(1 - x ^ 2) + Cx ^ 2 (1 + x) + Dx ^ 2 (1 - x)[/tex].
Now plug some value of x in the RHS of the equation and solvwe for x. You'll need to plug in at least 4 values of x, since there are 4 unknowns (A, B, C, and D). You can choose the value of x such that the RHS become as simple as possible. For example, you can choose x = 0 (A, C, and D will disappear in the RHS), x = 1 (A, B, D will disappear), x = -1 (A, B, C will disappear), and choose a random x (since you'll need 4 values of x) (e.g: x = 2).
The second way is to notice that the LHS of this equation:
is an even function, so the RHS must also be an even function.
That means:
[tex]\frac{1}{x ^ 2 (1 - x ^ 2)} = \frac{A}{x} + \frac{B}{x ^ 2} + \frac{C}{1 - x} + \frac{D}{1 + x} = - \frac{A}{x} + \frac{B}{x ^ 2} + \frac{C}{1 + x} + \frac{D}{1 - x}[/tex].
That means A = 0, C = D, so you are left with 2 unknowns:
[tex]\frac{1}{x ^ 2 (1 - x ^ 2)} = \frac{B}{x ^ 2} + \frac{C}{1 - x} + \frac{C}{1 + x}[/tex].Plug in 2 values of x, and solve for B, and C.
The third way (even faster) is to notice the fact that:
[tex]\frac{1}{x ^ 2} + \frac{1}{1 - x ^ 2} = \frac{1 - x ^ 2 + x ^ 2}{x ^ 2 (1 - x ^ 2)} = \frac{1}{x ^ 2 (1 - x ^ 2)}[/tex].
So:
[tex]\frac{1}{x ^ 2 (1 - x ^ 2)} = \frac{1}{x ^ 2} + \frac{1}{1 - x ^ 2}[/tex].
Just do the same for [tex]\frac{1}{(1 - x ^ 2)} = \frac{1}{(1 - x) (1 + x)}[/tex]. Can you go from here?
FAQ: How to integrate 1/x^2 (1 - x^2)
What is the general formula for integrating 1/x^2 (1 - x^2)?
The general formula for integrating 1/x^2 (1 - x^2) is: ∫(1/x^2 (1 - x^2)) dx = ln|x| + C
Can the integral of 1/x^2 (1 - x^2) be solved using u-substitution?
Yes, the integral of 1/x^2 (1 - x^2) can be solved using u-substitution. Let u = 1 - x^2, then du = -2x dx. Substituting these values into the integral gives: ∫(1/x^2 (1 - x^2))dx = ∫-1/u du = -ln|u| + C = -ln|1-x^2| + C
Is there an alternative method for solving the integral of 1/x^2 (1 - x^2)?
Yes, another method for solving the integral of 1/x^2 (1 - x^2) is by using partial fractions. This involves breaking down the rational function into simpler fractions and solving for the individual integrals.
Are there any special cases to consider when integrating 1/x^2 (1 - x^2)?
Yes, when integrating 1/x^2 (1 - x^2), it is important to consider the domain of x. Since the function has a singularity at x = 0, the integral must be evaluated for x < 0 and x > 0 separately.
Can the integral of 1/x^2 (1 - x^2) be evaluated using numerical methods?
Yes, the integral of 1/x^2 (1 - x^2) can be evaluated using numerical methods such as the trapezoidal rule or Simpson's rule. These methods use numerical approximations to calculate the value of the integral.
