How to Integrate Partial Fraction Problems without a Prefix
  • Thread starter Thread starter Youngster
    Fraction Partial
Youngster
\int\frac{8x^{2}+5x+8}{x^{3}-1}
Because the denominator can be reduced to (x-1)(x^{2}+x+1), I set up the partial fractions to be \frac{A}{(x-1)} + \frac{Bx+C}{(x^{2}+x+1)}
I've solved for A, B, and C, and now have the integral set up as such:
7\int\frac{dx}{x-1} + \int\frac{x-1}{x^{2}+x+1}dx
Where A is 7, B is 1, and C is -1
I can integrate the first term simply, but I'm having trouble figuring out how to integrate the second term. The best I can think of is a u substitution, but du turns into 2x+1 dx, which is nothing like x-1 dx. Any suggestions?
Write x-1=(1/2)*(2x+1)-3/2. Now you can easily do the 2x+1 part. The -3/2 part is harder. You'll need to complete the square in the denominator and do a trig substitution.
Complete the square on the other integral. I believe you'll get an arctan in the solution.
Ah, I see now. It's been a while since I've done that, but it works. I suppose I should do similar exercises to get this in my head.
And yeah, part of the integral turned out to be an inverse tangent one. Thanks a lot.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
