B How to interpret Pascal's Triangle for negative numbers?
An extended version of Pascal's Triangle can be interpreted for negative numbers, maintaining the same magnitudes as the standard triangle. The interpretation as the sum of all possible paths to a member is applicable to this extended version, following the same logic as the standard triangle. Understanding how the signs are allocated and how the rearrangement works is crucial for clarity on this topic. While some participants question the physical significance of Pascal's Triangle, it is primarily viewed as a representation of a recurrence relation rather than a model with physical implications. Overall, the discussion emphasizes the mathematical relationships and patterns inherent in both the standard and negative versions of Pascal's Triangle.
PLAGUE
TL;DR Summary
Intuition behind extended Pascal's Triangle.
This answer shows an extended version of Pascal's Triangle that works for negative numbers too.
In This video, Sal shows how to interpret the members of Pascal's Triangle as the sum of all the possible paths to get to that member.
Is there any way we can use this same 'sum of all the possible paths' to interpret This extended version of Pascal's Triangle?
Mathematics news on Phys.org
I'm not going to watch a video, but the interpretation as the sum of all possible paths follows directly from the interpretation as the sum of two entries in the preceding row: think about it.
Can you see that the magnitude of the numbers in the 'negative Pascal's triangle' are the same as those in the normal version? Can you work out how the rearrangement works? Can you work out how the signs are allocated?
Once you have done this the answer should be clear, not just to your question but to how any fact about the normal Pascal's triangle translates to the negative one.
I think I know the answers to your questions.
But is there any physical significance at all?
IMHO Pascal's triangle has no 'physical significance', it is just a diagrammatic representation of a recurrence relation. It is interesting that the diagram displays more patterns than one might expect, but these result from the underlying recurrence relation not from the diagram.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
