How to learn making circuit from the beginning?
In summary, you need to study electronics in order to build the circuit you want to blink the LED with. You can use a 555 timer to do this.
jamesdo
Hi,
I have to set up an experiment of Visible Light Communication system in which the transmitter is LED and the receiver is smartphone camera. I just have knowledge about networking and programming. So right now I have no idea how to build a circuit to make the LED blink to represent 0 and 1 bits. I'm reading the book "The art of electronics" by Paul Horowitz and Winfield Hill. While this book is not so difficult to read, I feel that it goes too deep into electronic. Honestly I don't know what I need to study to build the circuit I want. I just feel that I need to know how the logic gates (e.g. DDL, TTL, MOS FET) operate. How to connect them in one circuit.
Maybe it'll be too hard for me to make the entire circuit from the scratch. I heard that I can use some existing integrated circuit which I can do some programming with it. For example these chips will generate rectangle pulses and I just need to connect the LED to the output of the chips to get the output light blinking. So the next question is how to know the rule of making the circuit with these chips. And how to program the chip to generate the desired pulse.
I know I cannot get the answer in this forum. I just hope you can give me some advice based on your experiences. What is the shortest way for me to make the circuit I want. The book I mentioned above might be great but it doesn't say anything about the chip programming. Is there any book focusing on the part I need to know (logic gates, some basic chips, making circuit from chips, programming with them)?
The easiest way to make an LED blink is to use a 555 timer. For example
http://www.instructables.com/id/555-IC-Intro-Flashing-LED/
If you search for 555 LED blink you will get lots of hits.
It is hard for me to know how much usable knowledge you might get out of such an article given no electronics background.
Start your electronics constructor experience with something really simple. Then, when it doesn't work (a very common occurrence) you will have a chance of spotting what's wrong. Then move onwards and upwards in complexity. The time taken to reach a working complex circuit that way will almost certainly be less because you will be able to cope with each stage.
While the 55 time will blink the LED - if you want to communicate data, for examp[le in your experiment send a string of data - a basic micro controller(uC) would be better - for entry level an arduino would be pretty easy to use - cost would be ~ $ 20 - the base boards typically have the LED on them but you can use an external one as well.
Likes nsaspook
Since you are familiar with programming, maybe using a small hobby microcontroller board would be the easiest way to go:
http://makezine.com/magazine/make-43/a-smorgas-board-for-your-computing-pleasure/
:smile:
Likes sophiecentaur
Related to How to learn making circuit from the beginning?
1. What materials do I need to start learning how to make circuits?
To start learning how to make circuits, you will need a breadboard, various electronic components such as resistors, capacitors, and LEDs, a power supply, and wires. It is also helpful to have a multimeter for measuring and troubleshooting your circuits.
2. What is the best way to learn how to make circuits from the beginning?
The best way to learn how to make circuits is to start with the basics and gradually build upon your knowledge. You can find online tutorials, books, and even courses that cover the fundamentals of circuitry. It is also helpful to practice by following step-by-step instructions and then experimenting with your own designs.
3. Do I need any prior knowledge or experience to learn how to make circuits?
No, you do not need any prior knowledge or experience to learn how to make circuits. However, having a basic understanding of electricity and some math skills will make it easier to grasp the concepts and principles behind circuitry.
4. How can I troubleshoot my circuits if they are not working?
If your circuit is not working, the first step is to check your connections and make sure everything is properly connected. You can also use a multimeter to check for continuity and measure the voltage and resistance in your circuit. It is also helpful to have a schematic or diagram of your circuit to reference.
5. Are there any safety precautions I should take when learning how to make circuits?
Yes, it is important to always practice safety when working with circuits. Make sure your power supply is turned off before connecting or disconnecting components. Use proper insulation and avoid touching live wires. It is also helpful to work in a well-ventilated area and wear safety goggles when soldering.
  • Electrical Engineering
